JDM ITR shocks and springs on JDM CRX SiR?
Hey guys!
I really need your help...would a set of factory JDM DC2 Integra Type R shocks and springs fit in my JDM EF8 CRX SiR? I know you need the EG/DC front drop fork (which I already have) but will the rears bolt up?
Please let me know! especially someone who has actually done this.
Thanks!!!
Steve
Thanks!!!
Steve
if your car is a 88 then it might i have a 88 si and they work for me just go look in the back under the car near the tire and you can see if the bolt will fit in
well, it is std Type R shocks, with neuspeed race springs....but hmm, stands quite high does it.....that means it would take a bit to lower it, and the neuspeed race springs wouldnt take the wheels that close to the guard, hrm
Using lowered CR-X springs will bottom out the ITR shock and will cause bad handling and a bouncy ride. Any Teg(DC2) Shock is an inch or so taller than a CR-X shock. You would be better of using you stock shocks than ITR unless yours are blown.
trianglegreg
Dec 13, 2005 06:14 PM
YellowCSP
Feb 20, 2002 05:21 PM
