WTB- Hydro half shaft, aftermarket rods, pistons, valve cover
Old May 28, 2008 | 05:01 PM
B16aCRXSi's Avatar
Default WTB- Hydro half shaft, aftermarket rods, pistons, valve cover
I need pretty much everything that goes on the block, i have a B20B motor and GSR head, and B16 tranny, have a spun bearing, and i need rods and pistons, starter, alternater, and alternater bracket, oil pressure sending unit and the plugs in the back, everything, i need anything and every thing, let me know what you got, got a golden eagle b20 vtec conversion let me know i need that too 40/40 prop valve, ARP head studs rod bolts, what ever i live 10 min away from NE philly, 5 min from Trenton NJ and all around, let me know heres a better list
Distributor OBD-1
Type R Valve Cover
Intake Manifold-Skunk 2 or better
Throttle Body
Motor mounts
Clutch
Flywheel
Shift linkage
ECU
Axels
Rods and bearings- ARP and ACL
B20 Vtec conversion
Starter
40/40 prob valve
gotta be clean, low miles or new no junk i aint beat, show me what you got asap
Old May 30, 2008 | 06:19 AM
B16aCRXSi's Avatar
Default Re: WTB- Hydro half shaft, aftermarket rods, pistons, valve cover (B16aCRXSi)
anyone got anything
Old Jun 3, 2008 | 04:48 AM
B16aCRXSi's Avatar
bump anyone, i need everthing
Old Jun 15, 2008 | 05:26 PM
B16aCRXSi's Avatar
up top
tiemze
Welding / Fabrication
13
Jun 9, 2013 12:13 AM
dodger
Aug 27, 2011 07:14 AM
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
allnapower
Apr 22, 2005 10:27 AM
blackcruzan
10
Dec 25, 2003 01:42 PM
