93 accord with H22 Help!!!!!!
HI every one, i want to buy a 93 Accord and plan to put a H22 in it, i have a couple questions.1- will the h22 fit the an auto Tran? that IF i end up with an auto Tran
2- can i keep the curren ecu or i have to get the ecu that come with the engine?
3- it the h22 bolt right on the 93 accord chassi?
4- What more do i need to get this project to be done please let me know
1. The h22 will fit with an auto tranny
2. You have to get a new ECU (P13 or chipped ECU) and TCU (Transmission Control Unit)
3. Yes it bolts right in except you have to drill and tap a hole in the transmission to keep the f series mount.
4. Wire up the knock sensor, vtec harness, Depending if you have the ex or not you might have to wire in the iab's, Thats all i can think of as of now.
