Having trouble with holesaw ARGH!!!
Old May 28, 2008 | 01:36 PM
DrGrEeNtHuMb's Avatar
Default Having trouble with holesaw ARGH!!!
Ok, so I'm trying to make the holes in my firewall for my relocated battery terminals (the ones from Summit) but everytime I use the hole saw adapter I break the drill bit and fuc.k up my firewall. What did you guys use and and links or pics of the tools so I can ask my tool guyy?
Old May 28, 2008 | 05:07 PM
KFMRC's Avatar
I have to think your probably breaking or bending the bit when it punches thru. Try drilling a pilot hole just slightly smaller then the bit on the hole saw which is usually 1/4 and then go easy and it will cut right thru
Old May 28, 2008 | 06:43 PM
BlakeJ53's Avatar
Default Re: Having trouble with holesaw ARGH!!! (DrGrEeNtHuMb)
try some cutting fluid too
Old May 28, 2008 | 07:11 PM
TurbochargedInnovation's Avatar
Default Re: Having trouble with holesaw ARGH!!! (BlakeJ53)
try not to use much force.. and slower speeds, little wd40, and let the bit do the work.
Old May 29, 2008 | 06:26 AM
shortyz21's Avatar
Default Re: Having trouble with holesaw ARGH!!! (TurbochargedInnovation)
make sure your on a flat piece.
any curves will [freak] you right up
Old May 29, 2008 | 07:32 AM
qksl2's Avatar
Default Re: Having trouble with holesaw ARGH!!! (shortyz21)
Definitely all about the pilot hole. I find high speed low pressure works best with a hole saw.
Ian
Old May 30, 2008 | 12:04 PM
welfarepc's Avatar
when ever cutting through metal i always go slow, otherwise you just wear the teeth off your tools
Modified by welfarepc at 6:43 PM 5/30/2008
Old May 30, 2008 | 02:54 PM
jlude90's Avatar
you don't really need to go that slow if you're just cutting through the firewall, but cutting oil works much better then WD-40 or anything like that
just don't be afraid of using plenty of oil, its cheap, will save bits, and cut your hole faster
Old May 31, 2008 | 12:43 AM
P-Lucas's Avatar
Default Re: (jlude90)
put a 1/4" fender washer on the end of the pilot bit, this way when the pilot bit goes through the metal, the holesaw teeth will be covered by the washer and won't catch on the firewall as you go through. After you have your pilot hole remove the washer, and go slow like everyone is saying.
Old May 31, 2008 | 08:55 AM
Evile140's Avatar
If it is a big hole, and you don't plan on making a hundred holes run the drill backwards. If the metal you are trying to drill the hole in is uneven and has bends in it the teeth will catch and snap off the pilot bit pretty easily with it going forward.
Old May 31, 2008 | 09:47 AM
P-Lucas's Avatar
Default Re: (Evile140)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evile140 &raquo;</TD></TR><TR><TD CLASS="quote">If it is a big hole, and you don't plan on making a hundred holes run the drill backwards. If the metal you are trying to drill the hole in is uneven and has bends in it the teeth will catch and snap off the pilot bit pretty easily with it going forward.</TD></TR></TABLE>
x2
Old May 31, 2008 | 09:11 PM
Garage 808 Hatch's Avatar
Default Re: (P-Lucas)
go slow, dont press hard, you are most likely getting the pilot through and breaking when the hole saw actually hits. i drill uneven metal all the time with hole saws, its just takes time
Old Jun 1, 2008 | 02:10 PM
I am Ironman's Avatar
Default Re: (Garage 808 Hatch)
Drill the 1/4" hole first then put a 1/4" dowel in the hole saw and you will never have another problem.
Old Jun 4, 2008 | 07:57 PM
turboteener's Avatar
Banned
Get a Unibit. It is a much better choice for dilling though sheetmetal. To hell with that hole saw crap.
Muckman
Welding / Fabrication
12
Apr 11, 2008 09:50 AM
*Boostwerks*
47
Jul 2, 2006 05:53 AM
ineedhelp
10
Feb 4, 2006 06:44 AM
contender
Feb 4, 2005 09:00 AM
Feuerraeder
Jan 8, 2002 07:38 PM
