98 ITR rear seats in a 99-00 hatch?
How do I make 98 ITR rear seats fit in a 99-00 hatch. I've been searching a lot and get mixed reviews. I also tried putting them in myself, and nothing seems to line up or make any sense. Does anyone know how to make this happen?
-Thanks in advance.
-Thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">You need the DC2 tops and DB8 bottoms.</TD></TR></TABLE>
So theres no way to make it work with the dc2 bottoms?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard »</TD></TR><TR><TD CLASS="quote">
So theres no way to make it work with the dc2 bottoms?</TD></TR></TABLE>
Shove a rolled-up black beach towel in the gap?
Haha, what about making the backs fit right? What needs to be done?
just swap the frames from your ej/ek to the dc seats. for the upper.
you just have to cut all the clips on them, and then ziptie the dc pads to ej/ek frame.
for the lower.. the DB8 seat bottom works better. but you can just put padding under it and it works just as well.
if i said anything wrong. im sorry, im just a rookie and this is just from me doing research for my ej6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geneeunit »</TD></TR><TR><TD CLASS="quote">just swap the frames from your ej/ek to the dc seats. for the upper.
Thanks for the input man, I'll take a look into it.
</TD></TR></TABLE>Thanks for the input man, I'll take a look into it.
i had a how to bookmarked, but it dissapeared at the moment. it had a bunch of pictures. but its pretty straight forward. just cut all the clips off and then ziptie it back together and the top half will mount up perfectly.
EDIT:: if you cant get it, you can always let me have the seats.
buddy..
Modified by geneeunit at 3:14 PM 5/28/2008
buddy..Modified by geneeunit at 3:14 PM 5/28/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geneeunit »</TD></TR><TR><TD CLASS="quote">i had a how to bookmarked, but it dissapeared at the moment. it had a bunch of pictures. but its pretty straight forward. just cut all the clips off and then ziptie it back together and the top half will mount up perfectly.
buddy..
Modified by geneeunit at 3:14 PM 5/28/2008</TD></TR></TABLE>
Haha, thanks. What about the bottom (using the dc2)?...Seems like there would be more to it then just adding some padding.
buddy..Modified by geneeunit at 3:14 PM 5/28/2008</TD></TR></TABLE>
from what i've understood and read so far on other sites. bottom bolts up just fine, you just have to add some padding to help eliminate the gap between the top/bottom halfs.
but the DB bottom half is the better choice for ej/ek hatches while using the dc top half, why? i have no idea. Good Luck
if i ever find that how to with the pictures, ill post it.
EDIT:: https://honda-tech.com/zerothread/2196363
Modified by geneeunit at 11:18 PM 6/4/2008
Ejay Six
15
Apr 20, 2004 10:00 AM
