Add AC/PS into EG coupe w/ GSR swap.
Old May 28, 2008 | 08:15 AM
be3zy05's Avatar
Default Add AC/PS into EJ coupe w/ GSR swap.
My girl just bought an EJ EX coupe with a GSR swap and I want to get her AC and PS because shes complaining and I don't want to hear it anymore.
What do I need to get to add both of those?
Thanks
Modified by be3zy05 at 11:54 AM 5/28/2008
Old May 28, 2008 | 09:46 AM
TeamRPM_ZC's Avatar
Default Re: Add AC/PS into EG coupe w/ GSR swap. (be3zy05)
first of all, it's a EJ coupe, and second, i have ps and a/c, so i don't know how to install them, learn just by doing it and make sure theres enough space between the engine an stuff... but good luck on your girl thing, i got the same prob, but i was lucky that it came wit a/c and a swap for 900
Old May 28, 2008 | 11:19 AM
96cd5's Avatar
first of all get a B20 A/C bracket or a Del Sol VTEC A/C Bracket. Also called the P54 Bracket. Then get all the a/c stuff from a single cam eg including the compressor and u should have a/c.
Thats what i did on an EG.
As far as the PS i dont know yet, I am still working trying to find out which PS pump and bracket i need to use.
Good Luck!!!
Old May 28, 2008 | 11:29 AM
be3zy05's Avatar
Default Re: (96cd5)
Thanks. That is what I was hearing that you could use the b20 bracket.
Old May 28, 2008 | 11:46 AM
OMGWTFBBQ!'s Avatar
I did a b swap into an EK and I'm using the engine's PS pump and AC compressor, I just had to get spliced AC lines to fit the teggy compressor and civic condensor. My PS bolted right up though.
90lsvcrxva
Mar 27, 2012 03:59 PM
mikehawk
Jul 11, 2009 06:18 PM
HondaBurger
May 25, 2008 09:46 PM
PinkMaggit
Jan 9, 2006 06:58 PM
madman604
May 5, 2003 01:09 PM
