code 10...help!!!!
my ef hatch has been throwing a code 10 since i got it. its the only code its throwing. im pretty sure a code 10 is intake air temp so i changed out the sensor and it didnt change anything. so i plugged up my friends ecu and it still threw it. so does anyone know anything that will help. Thanx.
Modified by jons91ef at 5:15 AM 5/28/2008
was the engine swapped in it? - could have the wrong connector plugged into the IAT sensor - should be 2-wire connector with red/yellow and green/white wires
yeah i spun a rod bearing in my y8. So for now i threw my b7 in. But it has always thrown this code. I tried connecting in the other plug and reset the battery but it was still there
yeah i changed the sensor 2 times so I kinda figured that it was the wiring. So i found that one of the wires were messed with inside the wiring harness so I spliced it and ran it straight to the ecu. But same problem. Idk. Any other thoughts.
