Can you use an ABS hub/bearing assembly on a NON-ABS car?
Old May 27, 2008 | 10:31 PM
Nisif's Avatar
Default Can you use an ABS hub/bearing assembly on a NON-ABS car?
I came across a good deal on a set of brand new rear bearings/hub assembly for my integra rear brake swap. Can I use these on my NON-ABS brakes or would I need to press the abs ring off of the hub assembly?
Old May 28, 2008 | 09:55 AM
mugen si's Avatar
Default Re: Can you use an ABS hub/bearing assembly on a NON-ABS car? (Nisif)
if the hub will fit in place with the abs ring still installed, its fine to leave it on the hub assembly. But its very easy to press it off. I just did this to my em1. Just clamp the hub assembly into a vice and tap all around the ring with a hammer and punch. usually when you go to a parts store to get one, they will all come with an abs ring. its personal preference if you want it installed or not.
Old May 28, 2008 | 11:13 AM
hatchling37's Avatar
Default Re: Can you use an ABS hub/bearing assembly on a NON-ABS car? (mugen si)
You could also cut it off with a die grinder, just be careful not to hit the hub. Grind it down close to the hub, and then use a hammer and chisel and that beotch will come right off.
Old May 28, 2008 | 07:43 PM
Nisif's Avatar
Default Re: Can you use an ABS hub/bearing assembly on a NON-ABS car? (hatchling37)
Good to know, in that case I'll just leave the abs rings on if it won't interfere with anything.
Apple395
Jan 12, 2013 05:19 AM
nico91civic
Nov 12, 2008 09:04 AM
redman223
May 2, 2007 12:59 PM
saber1
Nov 3, 2004 07:53 AM
Matt B
Jun 18, 2004 08:41 AM
