obd0 and obd1 injector clips, are they different?
Old May 27, 2008 | 08:36 PM
D16SiHatch's Avatar
Default obd0 and obd1 injector clips, are they different?
So im about to start my b18b swap in a week or so once im out of school, and somethin just kinda popped in my head while i was reading through another thread. It occurs to me since i'll be using my stock Si d16a6 harness on the b18b engine with the rywire conversion harness, that the clips on that harness would also have to match the obd1 injector clips of the newer motor. At this point i haven't come across anything pertaining to this swap that mentions i'd have to change or remove and replace obd0 clips with obd1 clips. So i'm lead to assume that the si harness will hook up just fine to the newer injectors. Is that right, or am i completely in the wrong here lol?
And since im already making a thread on this, i figured ill inquire about somethin else as well. my rywire harness came in today. on the subharness there is the connection for the 4 wire o2, and also a connector for i believe the coolant temperature. lastly there is a small 1 wire connector but im not sure what its for. i glanced over the side of the engine but couldnt find a connector that this would plug into. anyone know what it could be for? i can get a pic too if it would help.
Old May 28, 2008 | 01:29 PM
D16SiHatch's Avatar
Default Re: obd0 and obd1 injector clips, are they different? (D16SiHatch)
ok well now that i got a chance to take a look at both clips in the light it would appear so far as i can tell, that they are identical.
I guess on to my next question. What does this connector go to thats off the rywire subharness? heres a pic
Modified by D16SiHatch at 1:28 AM 5/29/2008
Old May 28, 2008 | 01:57 PM
jlicrx's Avatar
we have done many OBD0 to OBD1 swaps and have never changed the injector clips - just plug right in
Old May 28, 2008 | 02:01 PM
jlicrx's Avatar
not too many one wire connectors on a harness - is it for the temp gauge? on the end of the head below the distributor
Old May 29, 2008 | 06:46 PM
D16SiHatch's Avatar
Default Re: obd0 and obd1 injector clips, are they different? (jlicrx)
actually the temp gauge is that two pin yellow connector on the subharness. i still dont know what the single black wire grey connector is for?
Old May 30, 2008 | 12:29 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">actually the temp gauge is that two pin yellow connector on the subharness. i still dont know what the single black wire grey connector is for?</TD></TR></TABLE>temp gauge sensor has one wire connector with yellow/green wire - sensor is located on the end of the head below the distributor (kind of between the distributor attaching arms) - engine coolant temp sensor TW for the ECU has 2-wire connector with red/white and green/white wires - also located on end of head toward the front of the car - temp sensor for cooling fan switch has 2-wire connector with yellow/green and black wires - located on back of the block by the oil filter on OBD0 engines and on thermostat housing on OBD1 engines
Modified by jlicrx at 2:43 PM 5/30/2008
Modified by jlicrx at 2:47 PM 5/30/2008
Old May 30, 2008 | 12:44 PM
D16SiHatch's Avatar
so your saying the temp gauge sensor with the one wire located on the end of the head below the distributor is where this clip is supposed to go? theres nothin on the head, or near it, that matches this silly *** connector.
I hopped on alldata to see what i could find. The ECT sensor is on the end of the head like ya said, and the wire colors are red/white, and green/blue. atleast on this b18b1 motor they are. the ECT gauge sending unit is directly next to it, and that is a one wire connection. However this connector in comparison to the one on the subharness are two totally different things. i'm still at a loss as to what this doohicky is supposed to be for.
dc5itracer
10
Mar 26, 2011 10:29 AM
bayron
13
Feb 26, 2009 08:04 PM
crx_si-r
Jun 24, 2008 02:05 PM
tyflip2
Mar 1, 2004 09:06 PM
