Gauge cluster swap now a CEL?
Old May 27, 2008 | 07:10 PM
SOHC_civic_si's Avatar
Default Gauge cluster swap now a CEL?
I recently swapped my gauge cluster from my 99 civic dx that had a tach and everything (in case your wondering why, I swapped it because the fuel and engine temp needles broke off ) to a JDM cluster.
heres the one i bought off ebay:
http://cgi.ebay.ca/JDM-96-00-C...sting .
Right after i hooked everything up and everything did directly hook up, my CEL came on? what could that be? I'm wondering maybe the CEL was on with my other cluster and the bulb was burnt out or something and i didn't know, because my engine was a problem where it randomly dies when I'm driving (see my other posts). any help would be great!!
Old May 27, 2008 | 07:18 PM
iluvmy2000civicex's Avatar
Default Re: Gauge cluster swap now a CEL? (SOHC_civic_si)
Go to AutoZone or wherever and have it checked to see if your throwing any codes. If so, fix them. If not, go from there.
Old May 27, 2008 | 07:25 PM
Default Re: Gauge cluster swap now a CEL? (iluvmy2000civicex)
I work at an oil change shop so I can just read the codes when I go to work tomorrow. I'm thinking though if it is just the cluster then what code could I get? And that just doesn't make sense to me at all so it had to be that light was burnt out or something because why would i get a code for a direct replacement cluster?
Old May 27, 2008 | 07:27 PM
You wouldnt get a code for a cluster. My guess is that you will be throwing a code when you check it 2moro.
Old May 27, 2008 | 07:38 PM
Yeah those are exactly my thoughts. I just hope its nothing major
Old May 27, 2008 | 07:45 PM
Prolly just your secondary o2 sensor like mine. Pretty much anyone with any exhaust mods has problems with their o2 sensors. The secondary o2 sensor just reads the catalyst efficiency in the catalytic converter. I have a high flow cat so I have no need for this sensor. It was already throwing a code so I didnt see any need in replacing it since I dont need it. I just removed it completely and live with the cel.
Old May 27, 2008 | 07:59 PM
Yeah that makes sense but both my O2 sensors are plugged into my header. I don't have a cat just straight piped. What is the 2nd 02 sensor even used for?
Old May 27, 2008 | 08:04 PM
If your secondary o2 sensor isnt plugged into an OEM cat it usually will make your cel come on. I almost promise you thats what it is. It pretty much just tells you if youre cat is good or not.
Old May 27, 2008 | 08:18 PM
Oh ok thats makes sense thanks. I will read the codes tomorrow and post back here to tell ya what they are. It would make sense then to convert your car to OBD1 so you can get get rid of your 2nd 02.
Old May 27, 2008 | 08:25 PM
cashkeith's Avatar
hey or sometime when you dont take the neg- off the batt. as u put new parts on it will throw the code bc its not stock
Old May 27, 2008 | 08:27 PM
Ok I will check back 2moro. I didnt convert it completely to OBD1 I just removed the secondary o2 sensor... the cel is still there.
Old May 27, 2008 | 08:30 PM
Default Re: Gauge cluster swap now a CEL? (cashkeith)
Its not going to throw a code bc he switch the cluster to another OEM cluster and didnt remove the negative battery cable. Removing that just resets the ECU. He said everything directly hooked up so its plug and play and so it is still "stock".
Old May 29, 2008 | 09:02 AM
Ok, I read the codes and since I don't know what they mean or how to interpret them, I will just write them exactly as how they came up:
P0113 (IAT)
Intake Air
Temperature Sensor -Circuit
High Input
P0420
P0420
Catalytic Convertor System -Efficiency
Below Threshold (Bank 1)
Any there they are. You were right about the cat, and I think the below threshold thing might be apart of the P0420 one, but as for the others I have no idea
Old May 29, 2008 | 09:25 AM
So I looked at the H-T sticky for reading CEL's and it turns out that the high input code, and all of them down from that are related to the cat, and the temperature sensor one is related to the P0113. The ones with the cat are to be expected since I don't have a cat, but for the IAT one, what could that be?
Old May 29, 2008 | 10:30 AM
ho bag's Avatar
Bad IAT sensor. Goto the junkyard and grab another one and replace it. 5 sec job max
Old May 29, 2008 | 10:34 AM
If you dont know what a IAT sensor is its the one that plugs into your intake before the throttle body and intake manifold. Just replace it. And I wouldnt worry about the other code.
Old May 30, 2008 | 04:37 PM
Ok sounds easy enough. I was thinking though that I have an ebay intake and the IAT sensor is literally taped into the little hole for the sensor since its ebay **** quality, so could that cause any problems or do I just need to replace it?
Old May 30, 2008 | 11:27 PM
-JAWSHUA-'s Avatar
stop buying from bad ebay stuff. I would say yes
Old May 31, 2008 | 04:02 PM
Default Re: (-JAWSHUA-)
lol it came with the car when i bought it. its the only ebay part on my car thankfully. i'm still going to replace the iat and if it doesn't fix the problem then i'm going to put on a better intake
Old Jun 1, 2008 | 10:20 AM
Default Re: (SOHC_civic_si)
bump. is it worth it to put on an aem cai or just an aem short ram. i know cai make more power and have always thought that they make more power at the top end because of the longer tubing, but i read something saying they make more bottom end power? which one is right? i'm not concerned about water worries since it does not rain much here and i am willing to pay the extra for a few more ponies. would u say its worth it?
361 accord
Feb 2, 2009 06:14 PM
HondaTeKnology
Mar 2, 2008 08:51 PM
95LStizzy
Jan 3, 2006 03:12 PM
cibola
Jun 3, 2005 04:56 PM
