k20 or k24 on a crx
Old May 27, 2008 | 06:46 PM
crxnatic's Avatar
Default k20 or k24 on a crx
i have a friend that owns a body shop and has a wrecked crv with a k24 automatic he wants to sell the motor for cheap so my question is can i get a rsx type s manual transmission and put it on the k24 or it cannot be done. please let me know cause is a pretty good deal and also how much do you think it takes to get a k series on a crx to make it run . including mods in mounts and everything?????
Old May 27, 2008 | 06:52 PM
89hatcher's Avatar
you would have to cut hood to clear an k-series with a stock hood. i say if money isn't an option go for it. you you actually spend some scripts to put a k-series in an ef. but if you look in all the right places and try to find some deals then it can be a budget k-series build. i say if its cheap go for it.
Old May 27, 2008 | 06:54 PM
Mr. Giggles's Avatar
Default Re: k20 or k24 on a crx (crxnatic)
k20a.org
Old May 28, 2008 | 05:58 AM
~sp33~'s Avatar
EFB055
Default FV-QR
It's easy, goes in like butter, you should buy it.
Old May 28, 2008 | 06:25 AM
Red_ED8's Avatar
Default Re: FV-QR (~sp33~)
Yes a rsx-s (k20a2) tranny can bolt up to a k24. Your going to have to either get a JDM style hood and cut the webbing or just cut the crap out of your stock hood. Enjoy the torque
Old May 28, 2008 | 09:56 AM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxnatic &raquo;</TD></TR><TR><TD CLASS="quote">how much do you think it takes to get a k series on a crx to make it run . including mods in mounts and everything?????</TD></TR></TABLE>
mounts from HASport are 750 new.
You need Kpro to remove the immobilzer from the ECU which is 900 something.
Axles from a base rsx.
You'll have to fabricate a way to run your shift cables. Karcepts sells a kit for EG's that EF owners modify to fit. That kit is around 200 I want to say.
There are other small things that I'm missing, but it's an expensive swap. If your getting the motor for cheap though, it will cut down your costs.
Search, check the FAQ, and http://www.k20a.org
http://www.norcalcrx.org/dropp...o.htm
http://www.crxbart.com/K20swap.html
Old May 28, 2008 | 11:04 AM
89hatcher's Avatar
either way you would have to cut a hole in your jdm style hood because the k24 sits way to high
k20rex
Feb 28, 2010 06:05 PM
enhancedCL9
25
Feb 6, 2003 06:14 AM
Driven
Feb 22, 2002 12:18 PM
