Just changed the transmission fluid on my 92 civic dx
Old May 27, 2008 | 06:30 PM
krisfnbs's Avatar
Default Just changed the transmission fluid on my 92 civic dx
Man it was soooo easy. I cant believe last time I had a shop do it for me. It was literally get that tight *** bolt off, with an air gun thing...let it drain, change ring, tighten back on, and fill.
My only question was I made sure I had it on a flat surface, when I added the new tranny fluid(bought at honda dealership), I added 2 quarts. I saw here on the forums that my tranny only held 1.9 and that it would leak some. I never got a leak. Is 2 quarts enough?
My shifts for my automatic is much better.
Old May 27, 2008 | 06:49 PM
iluvmy2000civicex's Avatar
Default Re: Just changed the transmission fluid on my 92 civic dx (krisfnbs)
Everything on a Honda is pretty easy.
Old May 27, 2008 | 07:52 PM
sw388's Avatar
Default Re: Just changed the transmission fluid on my 92 civic dx (iluvmy2000civicex)
x2 lol
Old May 28, 2008 | 08:09 AM
krisfnbs's Avatar
bump
Old May 28, 2008 | 08:53 AM
TOO MUCH TORQUE's Avatar
auto tranny holds like 8 quarts. if you want to clean it all up you need to do this process 3 or 4 times
Old May 28, 2008 | 08:59 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (TOO MUCH TORQUE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOO MUCH TORQUE &raquo;</TD></TR><TR><TD CLASS="quote">auto tranny holds like 8 quarts. if you want to clean it all up you need to do this process 3 or 4 times</TD></TR></TABLE>
eeerrr...&gt;WRONG
His auto trans holds 2.9 qts drain and fill...full capacity is around 5, but thats after draining the torque converter and all valve bodies etc.
Hondas are fine to just drain and fill using ONLY Honda ATF Z-1
Old May 28, 2008 | 09:00 AM
Evs-One's Avatar
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iluvmy2000civicex &raquo;</TD></TR><TR><TD CLASS="quote">Everything on a Honda is pretty easy.</TD></TR></TABLE>
umm...sure
Old May 30, 2008 | 08:26 AM
krisfnbs's Avatar
Default Re: Just changed the transmission fluid on my 92 civic dx (Evs-One)
Okay so should I put more than 2 quarts of tranny fluid in it? I did use the fluid from the dealer...
Is 2 quarts enough or should I max out the tranny???
Old May 30, 2008 | 01:20 PM
Evs-One's Avatar
Solbros Owns Me
you have a dip stick for the auto trans....check it:
on a flat surface
warmed up
engine off
Old May 30, 2008 | 01:22 PM
blk92_d16's Avatar
Yeah, if you have an auto trans then you're a bit short on fluid. Fill'r up bud!
Old May 30, 2008 | 04:06 PM
krisfnbs's Avatar
Default Re: (blk92_d16)
so filling up the tranny is good? I will definately buy another quart and filler up if you guys recommend that.
I know that I have 2 quarts in it, because when I drained it... it was on a flat surface, and when I filled it, no spillage came.
So my tranny can hold about 2.9 quarts?
Old May 31, 2008 | 07:51 AM
krisfnbs's Avatar
So I should fill up the tranny untilit starts comin out?.......just want to make sure guys.
4potnick
Mar 26, 2006 07:19 AM
racekar
Nov 1, 2004 02:43 PM
Deemeetree
Sep 28, 2004 08:14 PM
ModlesSI
Sep 17, 2002 01:22 AM
