my crx story......
Ok, I bought my 1990 crx si 3 months ago already had a jdm b16 swap in it. Guy i bought it off of didn't know what was wrong with it and was frustrated trying to fix it. The guy said it was a eletrical. I picked it up for dirt cheap and replaced the engine wiring harness but that still didn't fix the problem and it still won't turn over.
Just wondering what would be the best way to approach the situation? Tow it to a mechanic or any other options to try. Replace all the wiring in the whole car? Im runnin out of options.....
thanks
thanks
i looked up the ecu on hondata and its correct, the harness is correct i got the rywire vtec one as well on there. the engine will not turn over at all.
Modified by pushit84 at 9:38 PM 5/27/2008
Can you push start it?
What happens when you turn the ignition to the "on" position?
do the dash lights come on? can you hear a click (main relay), and a Hum from the back (fuel pump)?
is there voltage going to the starter?
is there spark? is the distributor okay, is the rotor loose?
Can you push start it? havent tried (up on jack stands at the moment)
yes the lights come on and i do hear the main relay and humm from the back
i have to check on this
im not sure how to check for spark w/o the engine turning over...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushit84 »</TD></TR><TR><TD CLASS="quote">
oh and check the grounds, and don't forget the thermostat ground
tylerd92
Engine Management and Tuning
May 31, 2015 03:57 PM
Chunkaroo!
12
Nov 28, 2011 09:58 AM
8VEYBEYB
Jul 7, 2009 12:09 PM
