broken timing belt
Old May 27, 2008 | 05:13 PM
black0hatch's Avatar
Default broken timing belt
i started tearing into this motor i thought it just jumped timing but i can turn the crank pulley and the cam pulley dosnt turn. so does this mean the valves are bent? is there anyway to find out without pulling the head? aslo if they are bent can i just put another head on there or is the whole motor done??
Old May 27, 2008 | 05:25 PM
UfoTofU's Avatar
Default Re: broken timing belt (black0hatch)
Just take the valve cover off and then the upper timing belt cover. No need to remove the entire head to see if the timing belt is broken.
When you say you can turn the crank pulley and the cam pulley doesn't move.......can you directly see the cam pulley? If so you should be able to see if the timing belt is there or not.
Old May 27, 2008 | 06:24 PM
Default Re: broken timing belt (UfoTofU)
the timing belt is there some teeth broke off it im in the process of changing it i just wana know if theres a chance the valves are bent. i allready have the top cover off.
Old May 27, 2008 | 07:46 PM
D16SiHatch's Avatar
with the timing belt off try and spin the cam gear and see if it moves freely. if its stuck and wont budge then you have a big problem. best case you can replace with a new head and get it back on the road again. worst case the valves tore up the tops of the pistons, in which case the whole engines pretty much toast.
Old May 28, 2008 | 03:19 AM
~sp33~'s Avatar
EFB055
Default Re: broken timing belt (D16SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">with the timing belt off try and spin the cam gear and see if it moves freely. </TD></TR></TABLE>
Wouldn't it hit the top of the pistons?
Old May 28, 2008 | 04:05 AM
gator88's Avatar
Default Re: broken timing belt (~sp33~)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ &raquo;</TD></TR><TR><TD CLASS="quote">
Wouldn't it hit the top of the pistons?</TD></TR></TABLE>
i believe so
Old May 28, 2008 | 07:41 AM
D16SiHatch's Avatar
Default Re: broken timing belt (gator88)
depending on how close pistons are to the top it is possible that it may hit. but seeing as how your turning the cam gear by hand, your not going to do any damage. your not trying to make it do several revolutions, you're just trying to see if the cam will move somewhat and do it freely. If the valve bottoms got pulverized into the bottom of the head then the cam isn't going to budge.
Old May 28, 2008 | 12:38 PM
stoopidfast's Avatar
my car did the same thing and i was lucky it didnt bent any valves put new belt wp and tensioner on runs perfect
gravity73
Feb 9, 2014 03:05 PM
JwithTHEek
Jan 21, 2009 09:38 AM
thebleek
Oct 1, 2008 02:39 PM
teddy_dc2
Jul 6, 2006 09:15 AM
Shaun
Jun 14, 2006 06:29 AM
