Accord 91 Transmission doesn't shifts properly !
Old May 27, 2008 | 04:29 PM
xid002's Avatar
New User
Default Accord 91 Transmission doesn't shifts properly !
My 91 Accord LX auto stay on 2nd gear when i drive it and doesn't want to go faster than 30--35 /mpha nd the "S" (D4) light is on. checked TCU which is good other few things too.spent lots of money but still same problem . any one can help me out please whats wrong or problem it could be . thank you all .
Old May 27, 2008 | 04:35 PM
xid002's Avatar
New User
My 91 Accord LX auto stay on 2nd gear when i drive it and doesn't want to go faster than 30--35 /mpha nd the "S" (D4) light is on. checked TCU which is good other few things too.spent lots of money but still same problem . any one can help me out please whats wrong or problem it could be .Any suggestions? I sure would appreciate any help on this. thank you all .
Old May 27, 2008 | 04:45 PM
hondadude's Avatar
Default Re: (xid002)
How did you test the TCU?
Did you jumper the service check connector and see if there are any codes stored?
Most of the time I've seen a hard code; D4 light on all the time it is a bad TCU.
Old May 28, 2008 | 12:35 AM
xid002's Avatar
New User
Default Re: (hondadude)91 Accord LX auto Transmission doesn't shifts-- How did you test the TCU?
hello
thank you Hondadude for your post. well what i did was 1st bought a used TCU sam model same identical TCU and replace mine but didn't work ,same problem. next switch with another TCU with a 91Accord EX ( mine LX) ,still didn't work. the problem 1st occur when i tried to aviod a car coming towards me from side and ipressed the gas high to aviod any accident and thats its "S" sign turn on from the moment .once a while S sign used to go away for a while but now its on all the time. have no idea what i will do next, none can figure out ! one guy say some thing under gear box cxonnection might be lose but ckd every thing there too and still "S" stuck . please let me know any one anything about it. this is the only car have in my family. thank you all
Old Jun 5, 2008 | 05:13 PM
djkurious's Avatar
Any resolution on this? I am trying to buy an accord with the same issue. I can probably get it for dirt cheap if I knew the resolution on this.
VtecPrelude95
Nov 29, 2009 08:10 PM
blas0827
Dec 14, 2006 04:40 PM
FITaccord
Sep 24, 2004 06:46 PM
xhopesfall20
Sep 22, 2003 09:31 PM
