Having Problems with brand new B18 build
Old May 27, 2008 | 01:51 PM
EFaction's Avatar
Default Having Problems with brand new B18 build
I am just getting into Honda tuning and I am having some issues with my car that I just recently purchased. You may have seen the car because it was posted on this website for sale. It is a 1990 civic hatch with a b18 swap, I am told it is called a poor man's ITR swap. It has a b16 fuel map. Also the suspension is from an integra. I really like the car but after the drive home it started to spew a lot of oil on my driveway. I am pretty sure that it is the oil pan gasket so that is not that big of a deal. However after dinner I was going to pull the car into the garage to see if the gasket needed to be replaced. When I started to car it started fine but when I push the gas it bogs and sputters and then revs when it fights to about 3000 rpm's. Does anybody have any ideas. Oh the engine bay is wire tucked as well so I'm assuming most of the wires are not in the standard locations.
Old May 27, 2008 | 08:38 PM
b19coupe's Avatar
Default Re: Having Problems with brand new B18 build (EFaction)
You do realize that it would take a fully functional crystal ball to know what your problem is, don't you? It could be wiring issues, valve timing problems, fuel issues, or ignition system problems, to name a few.
Old May 28, 2008 | 08:51 AM
calvinPGMFI's Avatar
is this related the engine man?
Old May 28, 2008 | 08:51 PM
EFaction's Avatar
Default Re: (calvinPGMFI)
haha nice, and I do realize that and I have been talking to a mechanic and we have narrowed it down to the VTEC pressure switch and the Coolant Temp sensor. The ECU gave us the code for the pressure switch which apparently had a bad ground so we grounded that and then it gave us a code six which is the coolant temp sensor. So I guess I don't know what else I could ask but I'm all open to any idea's of how to fix it, where to get parts, how much they cost. Common other problems that people have with a build like this.
Old May 28, 2008 | 09:36 PM
b19coupe's Avatar
Default Re: (EFaction)
Datalog your ECT. You may have the connectors switched.
Old May 29, 2008 | 09:02 AM
EFaction's Avatar
Default Re: (b19coupe)
ok another noob question here. How would I go about "Data logging" my ECT
Old May 29, 2008 | 10:12 AM
98vtec's Avatar
moderator emeritus
take your car to a professional.
Old May 29, 2008 | 07:00 PM
Josh C.'s Avatar
Default Re: (98vtec)
Ok so we fixed the problem with the ECT sensor now it is giving a Code 9. Any ideas, is there a list of things to check when a Code 9 comes up?
Old May 29, 2008 | 07:04 PM
b19coupe's Avatar
Default Re: (Josh C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Josh C. &raquo;</TD></TR><TR><TD CLASS="quote">Ok so we fixed the problem with the ECT sensor now it is giving a Code 9. </TD></TR></TABLE>
Distributor and distributor wiring.
Old May 30, 2008 | 04:37 AM
EFaction's Avatar
I'm fairly sure nothing is wrong with that because we took the top off and it is a brand new distributor. I mean brand new like it was taken out of a box and put on this car maybe a month ago. Could it be anything else?
Old May 30, 2008 | 05:08 AM
98vtec's Avatar
moderator emeritus
you came here asking for help, take it.
code 9 is the CYP sensor, a sensor that can only be fixed by replacing the distributor or diagnosing a problem with the wiring and fixing it.
buy a helms manual if you intend on working on your own car.
Old May 30, 2008 | 05:31 AM
EFaction's Avatar
sounds good man, will do
RiTtEk401
May 21, 2012 05:43 PM
bonamin
Jul 20, 2010 10:33 AM
jim9
Jun 25, 2010 06:19 PM
jim9
geminis2k
Mar 30, 2004 11:04 AM
