5 lug conv on 4 door uto
Was just wondering if it could be done an what al i need to do it i haesearched nd nobody has covered the topic and no im not converting to 5 speed car is for girlfriend and she cannot drive a manuel but does want things done to the car. so please help thanks.
1. Your girlfriend needs to learn to drive stick
2. The 5 lug conversion works just the same as it does with the other hondas. You have to by Integra Type R brake assemblies, and bigger axels as well, the whole package is available from password JDM for a little over $1000
Thats true. If you buy a CTR 5 lug conversion, you can run 32mm axels, but you will have to buy B series axels. I'm relatively sure that your stock axels won't work with the CTR breaks.
You might have to get custom axels made to fit a d series tranny and b series brakes, if you do then I would go with Gator Axels. But someone else on here might know which axels you can use.
