90-91 teg low idle/bog
Old May 27, 2008 | 12:59 PM
B16B_coupe's Avatar
HRD PKR
Default 90-91 teg low idle/bog
Posting this for a friend as he said he had searched...
his idle/take off is not goin so well
90 ls motor, the car's idle is around 500 rpm's
When taking off or free reving motor it sputters/ bog's intill 1200-1500rpm... Then anywhere above that it runs perfectly fine and smooth.
Old May 27, 2008 | 02:16 PM
HONDRETTI's Avatar
Default Re: 90-91 teg low idle/bog (B16B_coupe)
i recently had a similar-sounding problem, and it was a broken tps. could be a number of other things but you can start there.
Old May 27, 2008 | 02:24 PM
mr.beeks's Avatar
check timming first...
Old May 27, 2008 | 03:05 PM
sp3cialed's Avatar
I bought a 91 teg about a month ago. It had really bad bog between 1400-2000 rpm. Looked on g2ic and they said it was most likely o2 sensor. Swapped a new one in for like 24 bucks and everything was fixed.
Old May 29, 2008 | 09:00 AM
1990tegg's Avatar
Default Re: (sp3cialed)
i have also a '90, however it only does this when its the first start in the morning... once the car is up to running temp. it is smooth all the way...
KingRibbo
Aug 2, 2012 12:01 PM
lsturbo*
May 12, 2008 09:17 AM
R6E6I6D
Dec 4, 2004 02:25 PM
dubletke
Apr 18, 2002 07:26 PM
TurBoTeG
Nov 19, 2001 04:56 PM
