Skunk2 Pro1 (b-series) users
Old May 27, 2008 | 12:35 PM
00b18b's Avatar
Default Skunk2 Pro1 (b-series) users
I just finish degreeing the cams in, 98 in 105 ex per skunk2's spec sheet. I got +5 ex and +3 in...I just want to see what everyone else is getting so I'm not like totally off or anything. Total milling and decking is .018 with stock hg if anyone was wondering.
Old May 27, 2008 | 06:31 PM
stumpyf4's Avatar
Default Re: Skunk2 Pro1 (b-series) users (00b18b)
I'll post my gear settings when degree, hopefully I'll have a chance to do it this Friday afternoon.
Old May 27, 2008 | 08:28 PM
killerpenguin21's Avatar
whats your setup for degreeing (sorry i know off topic but im curious) i need to do it this winter.
Old May 27, 2008 | 08:51 PM
BadWay's Avatar
looks like you are right on target assuming you are using skunk tuner gears. i've degreed a few sets of these and every one of them comes out a little different, but the separation between the two gears is pretty much identical. now get it tuned
Old May 27, 2008 | 08:59 PM
00b18b's Avatar
Default Re: Skunk2 Pro1 (killerpenguin21)
what do you mean by setup? as in tools or procedure?
Old May 27, 2008 | 09:00 PM
00b18b's Avatar
Default Re: Skunk2 Pro1 (BadWay)
...using pro series gears
Old May 28, 2008 | 07:34 AM
Default Re: Skunk2 Pro1 (00b18b)
tools yeah...i want the setup from new england honda rebuilders but im broke...so curious if there is a cheaper setup.
Old May 28, 2008 | 08:37 AM
BRN12345's Avatar
Pro1's milled 0.02" .. after degree setting was +2,+2... Have you dynoed your car? It would be interesting to compare Pro1 hp curves
Old May 28, 2008 | 05:53 PM
00b18b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerpenguin21 &raquo;</TD></TR><TR><TD CLASS="quote">tools yeah...i want the setup from new england honda rebuilders but im broke...so curious if there is a cheaper setup.</TD></TR></TABLE>
A degree wheel from summit($22 bucks) and two loaner 7+in dial indicators(its always nice to know someone in a the machine shop industry). yo u can get by using just one dial indicator if money is tight. The new england honda builders fixture is sweet but I really cant justify that kinda spending unless I was doing this as a career.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRN12345 &raquo;</TD></TR><TR><TD CLASS="quote">Pro1's milled 0.02" .. after degree setting was +2,+2... Have you dynoed your car? It would be interesting to compare Pro1 hp curves</TD></TR></TABLE>
nope i just installed the engine today gonna start her up tomorrow and tune for idle and part throttle. Until I break-in the new clutch, I will tune for full throttle and dyno
Old Jun 30, 2008 | 10:38 AM
stumpyf4's Avatar
Just finished degreeing mine +3 intake and +4 exhaust. This is with Proseries cam gears. Head and block decked just enough to clean up.
Modified by stumpyf4 at 4:15 PM 6/30/2008
Old Jul 1, 2008 | 02:28 PM
soulpwr's Avatar
Default Re: Skunk2 Pro1 (stumpyf4)
Everybody's degree settings are gonna be different. Degreeing takes a lot of things into consideration. Belt tension/stretch, milling, decking, cam gear variations, the play between the timing gear and the crank etc.
Old Jul 2, 2008 | 03:47 PM
Natural Aspirations's Avatar
Default Re: (BRN12345)
You may wish to go back and double check your work, your probably running the valves dangerously close together.
Old Jul 2, 2008 | 05:14 PM
00b18b's Avatar
Default Re: Skunk2 Pro1 (soulpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulpwr &raquo;</TD></TR><TR><TD CLASS="quote">Everybody's degree settings are gonna be different. Degreeing takes a lot of things into consideration. Belt tension/stretch, milling, decking, cam gear variations, the play between the timing gear and the crank etc. </TD></TR></TABLE>
yes thank you for stating the obvious
Old Jul 2, 2008 | 10:09 PM
BRN12345's Avatar
Default Re: (Natural Aspirations)
Ran a few races with my +2,+2 setup and all reving to 9500rpm without problems.
Old Jul 3, 2008 | 12:25 AM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRN12345 &raquo;</TD></TR><TR><TD CLASS="quote">Ran a few races with my +2,+2 setup and all reving to 9500rpm without problems.</TD></TR></TABLE>
Yet
Old Jul 3, 2008 | 06:10 AM
BRN12345's Avatar
Why are you guys so sure that the valves will hit???
Old Jul 3, 2008 | 01:11 PM
IntegraType-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BRN12345 &raquo;</TD></TR><TR><TD CLASS="quote">Why are you guys so sure that the valves will hit??? </TD></TR></TABLE>
No they just say that for no reason at all :-\
+2+2 basically puts them to 0/0 if u think about it in theory.. they're not seperated enough just let that sit for a season..
"do you think the valves will hit"?
Old Jul 3, 2008 | 01:20 PM
I am not sure they will. But @ 2,2 they are close.
Old Jul 3, 2008 | 01:40 PM
BRN12345's Avatar
excuse my ignorance please, but when we built the engine (shaved head 0.02") and then degreed it. the 0 setting came to +2E,+1.75I... from there we fiddled with it on the dyno and made max power at +4E,+4I.
In your experiance, what is the best spread from the PRO1's?
Old Jul 4, 2008 | 05:55 AM
Its not necessarily what you did was incorrect, its just unusual. Did you do any valve to valve measurements? Are these authentic skunk cams? the Blox copies were said to be a bit off from the skunks and this would explain your skewed numbers.
Old Jul 4, 2008 | 04:30 PM
stumpyf4's Avatar
So I decided to check my V2V clearance
In +3, Ex +4 --&gt; V2V=0.055"
In +3, Ex +3 --&gt; V2V=0.048"
I didn't go adjust more because I will not risk running more overlap.
Head details:
-GSR Head
-Skunk2 Valves Std Compression
-RM Gen2 Springs Retainers
-Valve Job
Photos from In +3, Ex +3
Old Jul 4, 2008 | 07:22 PM
Default Re: (stumpyf4)
stumpyf4:
Was this with Vtec locked?
Old Jul 5, 2008 | 01:02 AM
stumpyf4's Avatar
Yep VTEC was locked and zero valve lash.
I was surprised by the amount of clearance too. Possibly combination of valve job and Skunk valves is increasing the clicking clearance.
Old Jul 5, 2008 | 06:28 AM
I only have exp with the Pro2's and they of coarse run quite a bit closer at that setting. .015-.020 at 0 on my head
blacK_Dc4
41
Nov 7, 2014 05:18 PM
jasperjohn
Feb 4, 2009 08:45 AM
xracerGS-R
Sep 13, 2004 08:39 AM
chet
Feb 18, 2003 04:25 PM
SystemGSR
Oct 24, 2002 11:40 AM
