GSR cam question
Hey I just got some custom grind cams
Cam specs are: Intake lift 0.461 and 293 degrees, and exhaust is 0.468 and 295 degrees
Mods are Intake, Intake manifold, hondata intake gasket, big tube tri-y header, dual valvesprings, ti retainers
Question is will my stock gsr valves be good for these cams?
Modified by prjctwhteg at 4:49 PM 5/27/2008
cams are a custom grind the specs are: Intake lift 0.461 and 293 degrees, and exhaust is 0.468 and 295 degrees
skunk 2 springs and retainers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prjctwhteg »</TD></TR><TR><TD CLASS="quote">
NOOO, your title has nothing to do with your question, and to answer your question, stock valves are good enough for basic FI setups so they will definately hold up for your minor NA build
Originally Posted by prjctwhteg
but that doesn't have anything to do with my question ... Are my stock gsr valves fine or should I just go ahead and replace my valves?</TD></TR></TABLE> ... Are my stock gsr valves fine or should I just go ahead and replace my valves?
