Front end pop/noise when gas/brake?
So I just installed D2 coilovers a week ago.
yesterday I drove to CT for an accord meet. Lots of potholes and stuff.
Now when I'm at a stop and give it gas, my car makes a POP noise kinda sounds like a balljoint. Same when I brake it goes pop...
Could it be the balljoint? or suspension or what?
To my knowledge all there is is the tie rod end or the lower balljoint could be messed up correct? or would it be my suspension already toast?
i'm no pro here but few stuff we could use:
-miles on car
-last time you change ur bushings
-ur engine mounts
-is your suspension seated correctly or tightened
-miles on car
-ur engine mounts
I had the same problem and I had both the frot Motor Mount out and the lower control arm bushings needed to be replaced. your problem sounds like a Motor mount.
GEOz2k7
Oct 30, 2008 11:08 PM
