funny engine idle
Old Jul 15, 2002 | 08:40 PM
SolidSpruce's Avatar
Default funny engine idle
ok im just about all out of ideas, i need some help! i changed the cylinder head on my 94 del sol (1.5 non vtec) i adjusted the timing changed the plugs wires distributor head gasket intake gasket ECU and it still idles funny, then when i rev it up and release the gas it dies out. I need some help please!!!!!!!!!!!!!!!!!!!!
Old Jul 15, 2002 | 08:43 PM
97hb's Avatar
Default Re: funny engine idle (SolidSpruce)
Maybe the IAC is clogged with some gunk. Check the map and tps sensors also.
Old Jul 15, 2002 | 09:31 PM
joeseph's Avatar
Default Re: funny engine idle (97hb)
Check the iac valve
Old Jul 16, 2002 | 02:33 AM
Mista Bone's Avatar
D Tranny Guru
what head did you use?
ignition timing at?
Not using a CRX Si head/cam are you?
Old Jul 16, 2002 | 04:14 AM
PHW's Avatar
PHW
I had some thing like that happen when I installed the head package on my girls SI, check your vacume hoses off the back of the manifold, vary good chance it will be one of those. Best way to check for leaks is with a propane test. It will find the leak quicker than your eyes will.
Dasnegro
12
Nov 22, 2013 10:36 AM
raider1qaz
Feb 1, 2013 12:44 PM
grnhatch94
Jan 27, 2008 03:10 PM
Got Snail 2
May 22, 2007 03:53 AM
miguel6632
Jul 2, 2005 08:58 AM
