got my gsr aligned, results inside..should I get a camber kit?
lowered on skunk2 coilovers , 1 1/2 fingerlength in the front, about 2 in the back.
Left front- -1.64 camber, 0 toe
Right front - -1.36 camber, 0.01 toe
left rear - -0.80 camber, 0.05 toe
right rear - -0.72 camber, 0.06 toe
I'm on potenza re730's with 60% tread left. I'm planning on new rims/tires in 16" in about 1-2 months. Should I bother with a camber kit? Or can I get by without one for awhile. I will probably eventually get one but I don't want to if it's not necessary.
[Modified by shattergsr, 9:30 PM 7/15/2002]
I've had my car droppped on Eibach sportline springs and Koni yellows for a few years and all I did was get an alignment and get the toe in check... on the rears I did the camber/washer trick where you put washers between where the upper control arm bolts to the body/frame to "shim" it out... I went from about -3 deg to like -1.8 deg for the rears w/ the washer.. the front is about the same I think .. I rotate my tires at every oil change (3K) and I haven't had really bad, uneven, or inside/camber wear on my tires so I didn't bother... my tires are pertty expensive.. if they showed signs of wear on the inside edges I'd get a kit.. but they don't so I didn't bother.. .
just keep your toe angles in check and rotate your tires, check the air pressures and you should be good to go ..works for my car..
yea I bought a lifetime alignment for $150 so I figure if I rotate/align them every oil change or so I should be okay. I'm getting brand new kumho 712 16" so I didn't want to wear them out fast...
i just went in to get my alignment done too...says they cant do anything about my camber until i get a camber kit..like i didnt know that. He said everything looked good, but my camber is at like 2 degrees or something like that! he said its pretty bad...lol, so now i'm in search for a pretty decent but cheap (price) front camber kit.
I can tell you right now that if you keep your tires rotated every 3K-5K miles you should not have any problems. I've had -2.1/-2.4 deg. camber left/right on my car for over 11K miles now and the tires are still even all the way across. Keep them rotated regularly and you'll be good to go.
Noah Santana
11
Jan 18, 2017 06:09 AM
