rear disc brakes
Old May 26, 2008 | 07:19 PM
gavinoauto's Avatar
Default rear disc brakes
Went to the junk today bought the rear disc brakes of a DA with brake cables. This is going on a 90 crx what else i need? Any help would be great thank you=]
Old May 26, 2008 | 07:24 PM
88todab16crx's Avatar
Default Re: rear disc brakes (gavinoauto)
thats about it i hope you got the whole trailing arm assembly
Old May 26, 2008 | 07:32 PM
ef yu's Avatar
Default Re: rear disc brakes (88todab16crx)
crx si 90-91 e-brake cables.
Da cables are too long. EF hatches are too long.
Old May 26, 2008 | 07:44 PM
akandok's Avatar
Dont forget to search on HT. There are articles upon articles on this.
and dont forget your 40/40 proportioning valve from the DA
Old May 26, 2008 | 07:58 PM
ef yu's Avatar
Default Re: (akandok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akandok &raquo;</TD></TR><TR><TD CLASS="quote">Dont forget to search on HT. There are articles upon articles on this.
and dont forget your 40/40 proportioning valve from the DA</TD></TR></TABLE>
not needed but its a plus. get from da integra RS* . without the abs .
Old May 26, 2008 | 08:53 PM
gavinoauto's Avatar
thanks you for the help=]
well i was looking at the arms and most of the bushings need to be replaced idk what to
get energy or stock i want it to be pretty stiff what you guys think?
Old May 26, 2008 | 09:15 PM
same ol Steve's Avatar
Default Re: (gavinoauto)
For a daily driver stock LCA bushings are fine,however the integra ones are larger diameter than the crx ones so make sure to get the da bushings.Braided stainless or at least new factory soft lines,4040 prop valve and larger diameter master cylinder also helps with pedal feel/travel
Use crx DISC brake e-brake cables also at least on my 91 hatch the swap moved the wheels out about 1/4 inch,enough that me tires rub after the swap while they didn't before with no other changes,my car is on H&R sport springs and running 15x7 -40 offset wheels 195/50-15 tires
Modified by same ol Steve at 10:21 PM 5/26/2008
Modified by same ol Steve at 10:23 PM 5/26/2008
Old May 27, 2008 | 03:12 AM
gibsanez's Avatar
Default Re: rear disc brakes (ef yu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef yu &raquo;</TD></TR><TR><TD CLASS="quote">crx si 90-91 e-brake cables.
I use Da cables in my EF and they work fine
Old May 27, 2008 | 03:21 AM
ef yu's Avatar
Default Re: rear disc brakes (gibsanez)
never said they wouldnt fit but i bet you have like what, extra 1feet of cable that hang loose under the car..
Old May 27, 2008 | 03:29 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef yu &raquo;</TD></TR><TR><TD CLASS="quote">never said they wouldnt fit but i bet you have like what, extra 1feet of cable that hang loose under the car..</TD></TR></TABLE>
Nope, they fit great. I don't understand what the big fuss is.
Old May 27, 2008 | 10:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, they fit great. I don't understand what the big fuss is.</TD></TR></TABLE>
if the OP's got a CRX which he says he has the da or hatch cables are to long
da's work fine on a hatch
Old May 27, 2008 | 10:56 AM
gibsanez's Avatar
Default Re: rear disc brakes (same ol Steve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by same ol Steve &raquo;</TD></TR><TR><TD CLASS="quote">
neato
Old May 27, 2008 | 03:48 PM
gavinoauto's Avatar
which is the master cylinder i need a pic if possible and what car i get it off
and i forgot to mention i got the rear assembly of a 4 door DA is that fine?
thanks again =]
Old May 27, 2008 | 04:39 PM
Look in the Civic Crx FAQ area theres a write-up in there,I have done the swap it doesn't really do much for a daily driver as for braking the disc assembly is actually heavier than the drums,it is fairly high on the bling factor. The 15/16" dia master if you want to get tricky you can just swap the hubs,rotors, calipers and e brake cables from one set of lca's to the other one of my friends has done it that way at least 5 times can be a bitch but can be done
Modified by same ol Steve at 5:55 PM 5/27/2008
alx_90ef
May 24, 2009 06:52 AM
CRX EF 88
17
Mar 25, 2007 04:54 PM
lazyboy
Nov 26, 2005 09:23 PM
crxsi541
Feb 1, 2005 12:13 PM
Gennady
Aug 6, 2003 12:12 PM
