miata rims?
Old May 26, 2008 | 06:04 PM
sinepome's Avatar
Default miata rims?
will miata rims fit on the ef? the bolt pattern is the same but i have not herd of anyone doing it. [IMG][/IMG]
Old May 26, 2008 | 07:08 PM
SlowB16's Avatar
They will fit after you get the hub bore bored to 56.1 mm or get 5mm spacers.
Someone correct me if I am wrong.
Old May 26, 2008 | 07:32 PM
traxxasx's Avatar
Default Re: (SlowB16)
they fit fine
Old May 26, 2008 | 09:57 PM
Smokinsax's Avatar
The Boot
Default Re: (traxxasx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx &raquo;</TD></TR><TR><TD CLASS="quote">they fit fine</TD></TR></TABLE>
after you do what the guy in the above post said.
From personal experience you need to bore out the hub center...never tried spacers though.
Old May 26, 2008 | 11:49 PM
Spoon Sports's Avatar
Suit up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowB16 &raquo;</TD></TR><TR><TD CLASS="quote">They will fit after you get the hub bore bored to 56.1 mm or get 5mm spacers.
Someone correct me if I am wrong.</TD></TR></TABLE>
They fit with spacer modification. I know because I bought a hatchback with miata rims
Old May 27, 2008 | 12:45 AM
K2e2vin's Avatar
Simple hole-saw works to bore out the center(doesn't have to go all the way through). I'm running '94 M-edition wheels right now.
Old May 27, 2008 | 08:30 AM
SlowB16's Avatar
Default Re: (K2e2vin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K2e2vin &raquo;</TD></TR><TR><TD CLASS="quote">Simple hole-saw works to bore out the center(doesn't have to go all the way through). I'm running '94 M-edition wheels right now.</TD></TR></TABLE>
What is a hole-saw if you don't mind me asking?
Old May 27, 2008 | 08:32 AM
SlowB16's Avatar
Ok I searched and I know what a holesaw is now. However, which size is closest to 56.1 mm??
Old May 27, 2008 | 09:19 AM
Laserjock's Avatar
56.1 / 25.4 = 2.20866142 inches
in for subscription
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowB16 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I searched and I know what a holesaw is now. However, which size is closest to 56.1 mm??</TD></TR></TABLE>
Old May 27, 2008 | 09:38 AM
fireant's Avatar
Default Re: (Laserjock)
Mine were done by a machinist. They can get it right and it should not cost much.
Old May 27, 2008 | 09:49 AM
es.roadster's Avatar
Default Re: miata rims? (sinepome)
miata wheels are lightweight. i rocked the daisys' on my ef but after a while, you would feel like that are getting uglier everytime you'd wash your car. but overall, these wheels are about the same weight as the hx wheels, just not as popular though. oh yeah, i'm using 3mm spacers. go for it
Old May 27, 2008 | 10:14 AM
K2e2vin's Avatar
Default Re: miata rims? (es.roadster)
Here's a quick shot I took(they're in the process of being painted black). I weighed them with a bathroom scale and they came out to 10.8lbs, and are supposedly wider than HX(6in vs. 5.5)
I bought the wheels with the hub bore already bored out, so I don't know what exact size he used; but from the pic I guess 2 1/4 is good.
Old May 27, 2008 | 12:24 PM
GroundZer0 336's Avatar
some of them fit without boring them or have spacers. i dont know which ones they are but had them on my crx and they fit. but i also had some like 2000 ones, the 16's and had to use spcers.
Old May 27, 2008 | 01:18 PM
Solid Motorsports's Avatar
You're right!
I can confirm this for the Panasport-looking ones from the 90-94 Miatas. They need to be bored to 56.1mm or run with 5mm spacers. The wheels use cone-seat lugnuts too. Take them to a machinist, shouldn't cost you more than $100 to have all four done, and you'll be safer having it bored fit the Honda hub instead of relying on your lugs for concentricity.
The wheels will not clear Honda's 10.3" front brakes, so the calipers will need to be ground down slightly for clearance, or you need those 5mm spacers.
Old May 27, 2008 | 01:34 PM
Default Re: miata rims? (K2e2vin)
try selling those first cus miata fanatics will love them
Old May 27, 2008 | 03:00 PM
sinepome's Avatar
yeah, those in the pic are the ones i was looking at thanks for all the help
Old May 27, 2008 | 11:08 PM
K2e2vin's Avatar
Default Re: (Solid Motorsports)
I don't know about the 90-93 ones, but the ones I have fit over 10.3" brakes just fine(you can't see it; but it's 91 EX knuckles/rotors with DA calipers on there).
Old May 30, 2008 | 09:33 AM
I can see the newer Miata wheels like those pictured above fitting over the brakes. The spokes are thinner and curve more, giving extra clearance. I have never fitted those wheels so I can't confirm.
The older wheels (90-94) that loosely resemble Panasports have 7 thick spokes that provide poor clearance. I needed to grind down my caliper slightly (only the outside corner edge, not the whole outer surface) to get those to fit over 10.3" front brakes.
Old Jun 2, 2008 | 10:54 AM
esoterEK..'s Avatar
i got the sunflower looking ones forsale if anyone's interested..
i havent bored out the center yet though..
Old Jun 26, 2008 | 02:04 PM
89MA70's Avatar
would the Panasport-looking 7 spoke wheels from the 90-94 Miata clear the front brakes and rear drum brakes of a 98 civic hatch?
i'm pretty sure i'll have to have it bored to 56.1mm, but i might just get the 5mm spacers.
j/w cuz i'm might be pickin a set up for $50.
Modified by 89MA70 at 3:29 PM 6/26/2008
Modified by 89MA70 at 3:30 PM 6/26/2008
Modified by 89MA70 at 3:45 PM 6/26/2008
Old Jun 27, 2008 | 10:37 PM
sinepome's Avatar
Default Re: (89MA70)
if the rims are only 50 you should get them anyways.
Old Jun 28, 2008 | 11:38 AM
89MA70's Avatar
well, i decided not to. i'm just gonna pick up a set of LS meshes..14's are a bit small for me, and i dont have to bore anything or use spacers.
Old Jul 9, 2008 | 04:43 PM
UnleashedEJ1's Avatar
I cant confirm with the miata wheels, but i have a set of 14" wheels on my EJ1 that wouldnt clear my hub so I tried spacers and I couldnt get enough treads on my lug nuts with stock studs for safe driving so my brother and I took them to his work, used the biggest drill bit they had and drilled out the center. and they fit perfect. I only had to drill into the wheel 3/8 to 1/2 to clear the hub. Sorry I dont know the exact diameter on the finished wheel.
Old Apr 16, 2009 | 08:25 AM
jmayhew's Avatar
anybody every try these
i have an opportunity to get them, but was wondering if anyone has tried?
anyone know the offset or if the bore is to small?
Old Apr 16, 2009 | 09:43 AM
nsxtasy's Avatar
H-T Order of Merit
The center bore on Miata/MX-5 wheels is 54.1 mm, which is indeed too small. At a minimum they would need to be bored out.
