1999 integra ECU/greddy emanage questions. (OBD2a or OBD2b??)
1999 integra GSR. P72 ECU. Greddy emanage. just checking to see if the last installer got everything wired up correctly. car dies/runs really lean as soon as it hitts boost.
Greddy reflashed the Emanage and we are still having the same problems. does anything need to be modified with the map sensor? like a check valve or missing link installed? also has anyone else had any problems with the emanage and a 99 GSR. also greddy told the owner he should not have to make any adjustments that it should just plug in and run.
just noticed the last installer left 2 wires unhooked. are they for the vtec control and are they needed for proper emanage contol? no were in the 99 gsr intructions does it talk about the vtec wires.
ps figured out the 99 GSR is obd2a and the preveous installer used the right diagram.
thanks
Modified by Snail Tuning at 9:16 PM 5/26/2008
thanks
Snail Tuning
Jun 3, 2008 04:45 PM
