check engine light
Old May 26, 2008 | 03:19 PM
sixgunsound's Avatar
Default check engine light
My check engine light is on in my 90 CRX Si with a ZC swap so i I pulled the carpet up to take a look at my ECU. The LED light blinks once, then 9 times then 20 times. The FAQ i read said that 1 means oxygen sensor which makes sense because that sensor is unhooked. It says 9 times means cylinder sensor and 20 times means electrical load detector. Can anybdy help me figure out why it might be throwing those two codes and how do I go about fixing it?
Old May 26, 2008 | 08:10 PM
hondasaurusrex's Avatar
Default Re: check engine light (sixgunsound)
if its a dohc zc, then the code 9 is your cam angle sensor, which means either your exhaust cam jumped a tooth, or the sensor is bad/wired up wrong....swap the 2 wires first and see if that fixes the code 9
code 20 is pretty self explanetory...you've got an excessive electrical load, or your alternator cant produce enough voltage/amperage
good luck
Old May 27, 2008 | 03:13 AM
gibsanez's Avatar
Default Re: check engine light (hondasaurusrex)
You could also have a bad harness or engine ground for ELD.
Old May 27, 2008 | 05:15 AM
thevtecnician's Avatar
Default Re: check engine light (gibsanez)
Your code 20 is most likely a ground somewhere. We see these kinds of threads all the time and that's usually the culprit. I even had my own code 20 once and it was the ground
Old May 27, 2008 | 08:31 AM
Default Re: check engine light (thevtecnician)
Yah my ground wires are all rotten. They're green haha. Ok well I'll change them and see what happens. As for the electrical load thing, my alternator is on the way out so I'll get a new one and hopefully that will help.
Old May 27, 2008 | 12:21 PM
BumbleBee Tuna's Avatar
you can replace them with fat gauge speaker wire from what i herd, they work just as well. but i went out and just got one of those hyperground cables because they look just down right sick!
Old May 27, 2008 | 06:03 PM
Default Re: check engine light (BumbleBee Tuna)
yah man that ground cable does look sweet. I have 4 gage speaker wire so I guess I'll give that a shot.
Kodyc
Feb 3, 2017 01:14 PM
samuel_gatech
Aug 26, 2006 01:56 PM
mengy007
13
May 15, 2006 02:30 PM
90SiHatchbk
Jun 7, 2004 05:50 PM
