hx rims on dc2 question...
Old May 26, 2008 | 12:48 PM
ImaHondaLover's Avatar
Default hx rims on dc2 question...
I have heard to put hx rims on an integra you need 5mm spacers. Is this right? Also, does it matter which ones I get or are ebay ones ok?
I'm also debating on lug nuts. I need oem honda since its an oem rim. Has anybody had oem honda open end lug nuts? Any info is appreciated.
Old May 26, 2008 | 04:56 PM
SkankyEJ7's Avatar
Default Re: hx rims on dc2 question... (ImaHondaLover)
I think you can also grind down the calipers. Check the Civic Faq's I think I may have seen a DIY on it there.
Old May 27, 2008 | 07:17 AM
dcfreak's Avatar
Default Re: hx rims on dc2 question... (SkankyEJ7)
ive seen people put washers on them also but not sure how well that works.
Old May 27, 2008 | 11:45 AM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Default Re: hx rims on dc2 question... (dcfreak)
yes youll need spacers for the fronts only, and i dont think it would matter where you bought your spacer from
Do you think 3mm spacers will be big enough?
Old May 28, 2008 | 10:43 PM
Old Jun 4, 2008 | 06:28 PM
sikfricks's Avatar
i just had washers on mine
Old Jun 4, 2008 | 08:27 PM
H22Ej1's Avatar
Shenanigans
Default Re: (sikfricks)
on an integra i belive 5mm front and rear are required, not sure if shaving the calipers is an option
on an eg civic fronts require 5mm spacers or shaving calipers, but it will clear the rears (both disc and drum types)
vtec95
Jan 20, 2011 01:31 PM
EG-SIXV-TEC
Jan 31, 2009 04:09 PM
WowOzYouRock
Honda S2000
31
Apr 25, 2006 11:29 AM
Wayne_Curr
Mar 17, 2006 11:26 AM
lv6l
26
Feb 19, 2006 11:53 AM
