Honda S2000 Honda S2000
Hi there, I have a problem :(
Old May 26, 2008 | 10:38 AM
Madman1886's Avatar
Default Hi there, I have a problem :(
Hi there, iam new to the site and was wondering if anyone can help me??? I have a 2003 S2K and iam getting a strange clunking noise when i change from first into reverse then move away, same if i go from reverse to first then move off, the sound comes just as i move off, not when the gears engaged. Sounds a bit like the brake pads moving but iam not sure, anyone else had any experiences like this, any input would be helpful !!!!!!! hope its not the prop
Old May 26, 2008 | 04:10 PM
Shy_GuyAP1's Avatar
I had the same problem, I forget exactly what it is, but if you have your hub nuts greased and retorqued to 220ft/lbs the clicking stops. It has something to do with the axles and hub disconnecting and reconnecting.
Old May 27, 2008 | 05:27 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (Shy_GuyAP1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madman1886 &raquo;</TD></TR><TR><TD CLASS="quote">Hi there, iam new to the site and was wondering if anyone can help me??? I have a 2003 S2K and iam getting a strange clunking noise when i change from first into reverse then move away, same if i go from reverse to first then move off, the sound comes just as i move off, not when the gears engaged. Sounds a bit like the brake pads moving but iam not sure, anyone else had any experiences like this, any input would be helpful !!!!!!! hope its not the prop </TD></TR></TABLE>
how many miles on the car???
Old May 27, 2008 | 07:24 AM
Madman1886's Avatar
Default Re: (S2KILLA)
Cheers dude, the car goes in for a service soon, so i'll get the garage to have a look at it!!!!
Old May 27, 2008 | 07:26 AM
Madman1886's Avatar
Default Re: (Madman1886)
The cars only done 26k dude, barely run in
Old May 27, 2008 | 08:41 AM
SuzukaBlueAP2's Avatar
my M04 w/ only 19K on the odometer does the same thing. I just have not had the opportunity to retorque yet.
Old May 27, 2008 | 09:14 AM
S2KILLA's Avatar
Default Re: (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">my M04 w/ only 19K on the odometer does the same thing. I just have not had the opportunity to retorque yet.</TD></TR></TABLE>
i did mine around 25k as well
Old May 27, 2008 | 09:30 AM
Madman1886's Avatar
No probs, i'll get the bolts retorqued and i'll go from there, cheers
Old May 27, 2008 | 10:15 AM
S2KILLA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madman1886 &raquo;</TD></TR><TR><TD CLASS="quote">No probs, i'll get the bolts retorqued and i'll go from there, cheers</TD></TR></TABLE>
nuts not bolts... just tryin to not make you look dumb when you ask the service guy
Old May 27, 2008 | 10:29 AM
Madman1886's Avatar
haha, no probs, i meant nuts, always get them mixed up, cheers anyway
Old May 28, 2008 | 09:28 PM
AnthraxVX's Avatar
well, i had clunking noise from my suspension, checked my tie rod ends, my sway bars and it wasnt either, the guys that did my alignment didnt torque the adjustmenst for caster and camber correctly and they got loose, just had to tighten them down. but i also do get on sometimes when i shift, something in the tranny but that one doesnt bother me, probably something with the syncros or the gears popping in and slapping.
TailZ
Honda Civic (2001 - 2005)
Oct 7, 2009 08:26 AM
FOMULA91
14
Mar 29, 2006 07:22 AM
Kyles ej1
12
Aug 30, 2004 07:09 PM
Crxer
Aug 23, 2002 08:10 PM
NWPNOMORE
Jun 20, 2002 10:22 PM
