another question
Old May 26, 2008 | 09:24 AM
91blackEF's Avatar
Default another question
i have a 1991 honda civic dx hatch in the center of the fire wall a little closer to the drivers side is this...
and heres a little closer picture...
when i had to take the dash off it wasent connected to anything under there eathier but im gunna be doing a b18b1 swap no a/c or anything just heat so if someone can let me know if i should remover it or what it might be for it would be appreciated thanks.
Old May 26, 2008 | 12:37 PM
BlueCrxNC's Avatar
That's your speedo cable. Use depends on the cluster gauge you plan to use. Plugs into the transmission. Normally routes through the firewall (grommet is missing), behind the heater box (center of dash) to the driverside, up into the cluster gauge area and into the back of the cluster itself.
Old May 26, 2008 | 01:00 PM
91blackEF's Avatar
Default Re: (BlueCrxNC)
alright thanks for the input man
paulff3
Sep 4, 2008 05:46 AM
pimpwagon
Jun 16, 2008 12:50 PM
rtnlsltn
May 30, 2007 10:00 AM
SnkyPY
Dec 27, 2003 10:53 AM
99Civic hatch
Oct 10, 2001 04:43 AM
