I have done the DPFI to MPFI, Looking to run OBD1 dizzy and injectors
Old May 26, 2008 | 08:05 AM
4gencivicef9's Avatar
Default I have done the DPFI to MPFI, Looking to run OBD1 dizzy and injectors
Ok I have a obd0 dizzy wired up what do I have to do to run the obd1 injectors can I get rid of the resistor box if so how? also I got extra plugs from a obd1 harness for the dizzy the small plug wires match, but the second plug does not I have blue/yellow, blue,2 white, orange,orange yellow or white cant tell old. 7 wires what is each wire. ?
I need a diagram for the dizzy to match them together thanks
Old May 26, 2008 | 08:14 AM
Default Re: I have done the DPFI to MPFI, Looking to run OBD1 dizzy and injectors (4gencivicef9)
ok I figured out the wiring for the injectors. I just need a diagram for the dizzy plugs for I can run the obd1 dizzy from obd0
Old May 26, 2008 | 10:20 AM
jdmef9red's Avatar
rywire sells the distributor swap harnesses there like 30 bucks on there website
Old May 26, 2008 | 12:57 PM
Default Re: I have done the DPFI to MPFI, Looking to run OBD1 dizzy and injectors (jdmef9red)
rywire no longer sells the dizzy jumper, I already checked it. thanks.
Old May 26, 2008 | 02:42 PM
Crx Jimmy's Avatar
xenocron tuning solutions sells the dizzy jumper harness do a google search his web site should come up
Old May 26, 2008 | 05:49 PM
Default Re: I have done the DPFI to MPFI, Looking to run OBD1 dizzy and injectors (Crx Jimmy)
thanks
Old May 27, 2008 | 10:49 AM
BIGGINS LS-VTEC's Avatar
save your money and just change connectors by re pining it
Old May 27, 2008 | 12:41 PM
Default Re: I have done the DPFI to MPFI, Looking to run OBD1 dizzy and injectors (BIGGINS LS-VTEC)
do you have the diagram for the connector it has one or more different color wires
Old Jun 3, 2008 | 03:57 PM
nitewolf's Avatar
ttt
Old Jun 3, 2008 | 04:45 PM
jdmb20boi's Avatar
please let me kno if u find the diagram or figure this one out.. i gotta do a dpfi to mpfi soon cause i got a 88standard and wanna d16z6 swap it..
m3kid
Apr 21, 2012 06:30 PM
Jake92eg
40
Feb 10, 2011 09:45 PM
jtroy917
Jun 3, 2007 02:54 PM
Fusion G2 Civic
14
Dec 22, 2005 09:49 AM
civicefdx
Oct 24, 2004 03:25 PM
