cam help
i have a b16 its about 11 to 1 i have a supertech valve train and skunk 2 stage 2 cams. im also running a jrsc on 11 lbs. i just finished my build and fired it up it runs but its only on 2 cylinders... 1 and 3.. i dont think its the spark plugs since i just put them in. could i have put the cams in wrong?
Technically you should be posting your question in the FI forum but I'm willing to bet it could be something as simple as a firing order problem (you have it mixed up) or your plug gaps are set too large for that amount of boost and compression.
i no its on 2 cylinders because my header turned color on 2 cylinders. ill check the plugs but i no the order is right i might have gaped the plugs wrong. thanks for the advise
