engine wont start...need help
ive seen this done b4 with some effective results. i live in so cal long beach. whoever can get my car started, theres an instant $40 in it
b16a..........
i just got my head back from the shop after bending a few valves cuz the timing belt jumped. now i put it back together and the engine sounds like it wants to start but it doesnt. when it gets close, theres backfire. i checked my cams and theyre aligned correct. im getting A code 6, coolant sensor, but i dont see how that would keep the engine from starting. another thing was when i put the distributor back on, the little outside fork wasnt aligned with the camshaft. so i kinda made it fit. ive heard that it could be completely upside down, but i dont think it would even fit up like that. how can i really check? any ideas?? TIA
[Modified by LB CRX, 2:50 AM 7/17/2002]
b16a..........
There's only one way for it to fit. The distributor and the camshaft have a fat line running almost down the middle, but it's offset so you don't have the distributor 180 degrees out of phase.
Since your hearing a backfire, there still has to be something off, in either the cam/crankshaft alignment or timming. It's sparking, while the valves are still open... Or something went wrong with the head rebuild, and a valve(s) are hanging open, and not seating properly...
i dont know if this is normal but when i tried to align the fork on the distributer, the fork would not rotate a full 360. it wouldnt even turn 180 degrees. it stopped like there was something stuck. could the rotor or somthing in the dist. be messed up?
javiergt02
15
Aug 21, 2006 07:37 PM
