Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
What does the 06 Si come with? Specs and Kpro
Old May 26, 2008 | 04:29 AM
RIZOBIZERT's Avatar
Default What does the 06 Si come with? Specs and Kpro
I'm looking for a 2006 Si and newer. I was wonder if it comes with the fly by wire throttle. Also,how about traction control? Does it still have the electric assist power steering and what are you thougths on that? I want to get a wreck car for a project and would simply strip the components I need. I know that Hondata is working on the Kpro, have they finished it yet? How is the ABS picked up? Is there a ring on the drive shaft, or is it picked up on the rotor? Can I eliminate the A/C just like any other K20 with a pulley set up? Do you happen to know the turns lock to lock on the Si? I think it's about 2.6, but just want to verify that. Thank for all your help in advance.
Old May 26, 2008 | 09:43 AM
Fueler^'s Avatar
Default Re: What does the 06 Si come with? Specs and Kpro (RIZOBIZERT)
http://www.honda.com
Old May 26, 2008 | 04:36 PM
RIZOBIZERT's Avatar
Default Re: What does the 06 Si come with? Specs and Kpro (Fueler^)
A little more insight would be appreciated. I'd like some opinions as well...like 'how do you like the electric steering?'. Thanks.
Old May 26, 2008 | 06:39 PM
KlickityClack07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIZOBIZERT &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking for a 2006 Si and newer. I was wonder if it comes with the fly by wire throttle. Also,how about traction control? Does it still have the electric assist power steering and what are you thougths on that? I want to get a wreck car for a project and would simply strip the components I need. I know that Hondata is working on the Kpro, have they finished it yet? How is the ABS picked up? Is there a ring on the drive shaft, or is it picked up on the rotor? Can I eliminate the A/C just like any other K20 with a pulley set up? Do you happen to know the turns lock to lock on the Si? I think it's about 2.6, but just want to verify that. Thank for all your help in advance. </TD></TR></TABLE>
Ill try and answer some of these... Comes with drive by wire, traction control is available for 07 Si's and up. Steering and handling is great. Hondata is not finished with Kpro and at this rate never will be. Thats all i know for sure...Hope that helps a little.
Old May 26, 2008 | 09:13 PM
i-VTEC_DOHC's Avatar
1.) vsa is a life-saver.
2.) electric steering is [freak]ing awesome.
3.) the abs is great. kinda noisy.
4.) yes u can eliminate the a/c just like any other car.
5.) i think the turns are 2.6 like u stated.
Old May 27, 2008 | 03:09 AM
RIZOBIZERT's Avatar
Default Re: (i-VTEC_DOHC)
Thanks for all your help.
Old May 27, 2008 | 12:33 PM
draken187's Avatar
Default Re: (RIZOBIZERT)
vsa does save ur life.
electric steering is amazing... it also gives ur engine more power as its not being used for the steering.. have that on both my cars
as stated above the abs is noisy.. its real sensitive... if i hit a pot hole while slightly touching my brake the abs freaks out and my friends go wtf.....
JDMCRX
Mar 2, 2011 06:33 PM
robarakira
19
May 17, 2009 03:18 PM
VTECengage
29
Apr 27, 2008 05:32 AM
jxhxb
12
May 3, 2007 06:10 PM
smokey2.0
Feb 16, 2003 06:43 PM
