WTB: 2x channel amp
Directed 750D Class D Mono Amplifier
For 2004, the Directed Audio digital amplifier family is stronger than ever. Our award-winning and powerful class D mono blocks are joined by the Tripath-powered model 1200t, that combines the raw power and efficiency of 1200 watts of class D bump, the pure sound quality of conventional class AB, and built-in digital intelligence.
*High speed MOSFET switching power
supply
*High current, high efficiency MOSFET
outputs
*Switchable 8 dB bass EQ
*180° phase invert switch
*Remote subwoofer level control function
*Thermal, DC offset, reverse polarity and
short circuit protection
outputs
Dynamic Power Rating: 750 watts
S/N: > 80 dB
Freq. Range: 20-250Hz
Damping Factor: > 50
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 275 x 1
Rated Power @ 2 ohm: 400 x 1
Rated Power @ 1 ohm: 600 x 1
Crossover: var. 18dB low-pass
Bass EQ: Yes 8 dB
RCA Output: Yes, mono
Protection: T,S,D,R,O,L T=thermal, S=short circuit, D=DC offset, R=reverse polarity, O=over/under voltage, L=status LED
will sell you this amp for 175 shipped
Dan@Assaultech
181
Jul 13, 2011 09:59 AM
Dxavier125
Aug 5, 2009 03:13 PM
hotroostersauce
Jun 13, 2009 12:54 AM
