no low end power
Old May 25, 2008 | 10:49 PM
lisajasmin's Avatar
Default no low end power
there seem to be no power on take off top end is real good i have b16a motor with type r head and intake manifold 310 rc injectors and also the check engine light on the code is for o2 sensor i change it but the light is still on any help will be appreciated
Old May 26, 2008 | 03:51 AM
gibsanez's Avatar
Default Re: no low end power (lisajasmin)
Check the O2 wiring.
You're car isn't going to have low end power anyways, it's a B16
Old May 26, 2008 | 07:00 AM
EG2Driver's Avatar
Default Re: no low end power (gibsanez)
my b16 had nothing under 3500 rpm. I think its normal. If you are used to Ds, then it totally normal because they have more low rpm "torque"
Old May 26, 2008 | 09:32 AM
baller status's Avatar
If your O2 sensor isn't working you'll have poor performance. Wide Open Throttle isn't affected as much since that falls into closed loop (ignores O2 sensor).
typeRef
Jul 3, 2014 03:19 PM
4d00rEF
Jan 15, 2010 07:10 PM
RoyMan
10
May 24, 2005 12:38 PM
TeamTooQuick
May 23, 2003 10:05 AM
