Please help!!!!!!!!!!!!!
Old May 25, 2008 | 07:53 PM
J_SHADOW's Avatar
Default Please help!!!!!!!!!!!!!
ok my friend gave me a b18b1 block with a block guard and ctr pistons i decided to do an ls/vtec and happen to grab a gsr head after i build the head and tapped it for ls/vtec now i been hearing ppl say that i can't use the head with them pistons can anyone please tell me if this is b*** or if there is any way around it like getting a thicker head gasket or what....... please help!!!!!!!
Old May 25, 2008 | 09:17 PM
TheShodan's Avatar
Moderator
Default Re: Please help!!!!!!!!!!!!! (J_SHADOW)
Compression will be TOO HIGH and you will more than guaranteed likely to have piston slap. Change the pistons or you will regret it.
Old May 25, 2008 | 10:20 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Please help!!!!!!!!!!!!! (TheShodan)
http://www.zealautowerks.com/index.html
Hit that up and find out how unhappy it will be.
Old May 26, 2008 | 02:35 AM
non-VTEC's Avatar
damn....that will give you over 14:1CR or more if the head/block was milled.
uhhh....ya you need to change out those pistons......
Old May 26, 2008 | 04:30 AM
IntegraType-R's Avatar
Default Re: Please help!!!!!!!!!!!!! (non-VTEC)
Use a different crank. or if you want the same effect use p30 pistons.
Old May 26, 2008 | 06:08 AM
J_SHADOW's Avatar
so what would you recomend?
Old May 26, 2008 | 07:22 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_SHADOW &raquo;</TD></TR><TR><TD CLASS="quote">so what would you recomend?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">Use a different crank. or if you want the same effect use p30 pistons.</TD></TR></TABLE>
Old May 26, 2008 | 10:37 AM
I'll help you out..
As it sits now.. 14.3 CR
GSR crank = 12.5
usdm c5 pistons = 11.9
pr3 b16 pistons = 12.2
p30 jdm b16 pistons = 12.5
p72 jdm gsr pistons = 11.4
Some might think your defeating the purpose of using a ls block.. but if your going to run those pistons, destroke or go with a p30 setup..89mm crank vs a 87mm actually makes a huge difference and people dont realize that.
Old May 26, 2008 | 10:50 AM
count me out's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Compression will be TOO HIGH and you will more than guaranteed likely to have piston slap. Change the pistons or you will regret it.</TD></TR></TABLE>
piston slap has to do with skirt to wall clearances, what does a high compression ratio have to do with that?
Old May 26, 2008 | 06:37 PM
non-VTEC's Avatar
i would use USDM ITR pistons. a hair under 12:1cr and you can easily run 91 octane with a good tune. it would be better/safer for a daily driver.
ben_art
13
Dec 2, 2014 03:09 PM
bakomack
Jul 18, 2010 10:37 PM
superturboprelude
May 12, 2007 01:47 PM
Civic
20
Oct 29, 2003 06:02 PM
