Need Help.. Car stop running
Ok guys my car has been acting up. Ill go through the story to fill you in. 88 crx si. It all started when i was almost out of gas so i went to fuel up got to the gas station fine and got gas. started back up and drove a mile and a half down the street and it starts sputtering then finally shuts off and would not start back up. So i towed it home and started looking. Cranks fine, all lights work. Did not hear the fuel pump. so i figured Main relay. changed the relay. nothing. changed the fuel pump nothing. changed the computer nothing. Its not getting fuel or spark. So i checked all the fuses and i came up with nothing blown. Im out of ideas on how to fix the problem of not starting. any help would be greatly appreciated.
Parts replaced
New Main relay
New Fuel Pump
Ecu out of running car PM6
Parts replaced
New Main relay
New Fuel Pump
mine did that the other day. Turns out, it was the set screw in the rotor that came out. I'd just double check that real quick. just my .02. Hope you get it goin soon,
StegRX
Feb 8, 2016 07:54 AM
CrxKid88Si
Jul 20, 2013 07:18 PM
