g23 cams what can i use
Old May 25, 2008 | 06:50 PM
ashb82's Avatar
Default g23 cams what can i use
i have a g23 f23 with h22 pistons and h22 head. I want to get cams. when i put the engine together i clayed the engine. I wrote down all the valve to pistons clearance and look like to me i could use a cam with another mm lift. so can i get a cam with 1 more mm lift
Old May 27, 2008 | 07:23 PM
wed3k's Avatar
whats the clearance?
Old May 28, 2008 | 05:22 AM
PirateMcFred's Avatar
Default Re: g23 cams what can i use (ashb82)
You'll probably have to re-clay it if you want anything particularly aggressive as cam profiles vary wildly and your H22 pistons in the F23 stick up a LOT.
Old May 28, 2008 | 08:09 PM
Turbowa's Avatar
Default Re: g23 cams what can i use (PirateMcFred)
Not to sound like a smart ***, but did you clay the motor with vtec locked? If not then this will be were the 1mm of clearance is coming from and when vtec engages you can say good bye to the motor.
Old May 29, 2008 | 12:33 PM
ashb82's Avatar
Default Re: g23 cams what can i use (Turbowa)
i think i know better than that. when i put it together took out .040 from the valve relief of the pistons. do you think that is going to be ok. I think i will just take the head off and check to make sure. It will only cost the price of a new head gasket just alot more time a 1 hr job to a all day job.and if the valves hit a weekend job.
slowaccord559
Apr 13, 2015 06:16 PM
projectef
Jul 11, 2008 02:33 PM
ashb82
May 22, 2008 10:36 PM
gabrielle
Nov 13, 2006 06:35 PM
NewOrleansH22
May 7, 2005 09:36 AM
