ATS Final Drive and Synchro install. Where to go?
Old Jul 15, 2002 | 06:41 PM
type r 01-1063's Avatar
Default ATS Final Drive and Synchro install. Where to go?
Which place in Southern Cali do you guys recommend taking my tranny to install
my ATS final drive and replace synchro's for me?
btw - my tranny is already removed from the engine. They just have to open the housing and do the work needed.
Old Jul 15, 2002 | 06:44 PM
Default Re: ATS Final Drive and Synchro install. Where to go? (type r 01-1063)
oh yea....originally I was intending to take it to the dealership but I like to know of any alternatives.
Old Jul 15, 2002 | 06:46 PM
AllMotorMadness's Avatar
take it to Jeff at Importbuilders
Old Jul 16, 2002 | 09:07 AM
ttt
Old Jul 16, 2002 | 09:12 AM
Chris's Avatar
Come over to my house..
Old Jul 16, 2002 | 09:37 AM
ITR-01-0977's Avatar
New User
Default Re: ATS Final Drive and Synchro install. Where to go? (Chris)
If you took a road trip to AZ my friend Chris could do it for you....He is a certified honda master tech.....and he did my ats fd for me. No problems what so ever. He can do your syncros no problem also.
Old Jul 16, 2002 | 09:45 AM
yoshi234's Avatar
I shoot brides
it would help us to know what part of socal you're in, unless you don't mind long drives
Old Jul 16, 2002 | 09:46 AM
Black R's Avatar
25 Year Member
helms = $60
diy = priceless
Old Jul 16, 2002 | 09:51 AM
Dave-ROR's Avatar
bring it to FL and I'll install it all
Old Jul 16, 2002 | 10:09 AM
Default Re: ATS Final Drive and Synchro install. Where to go? (Black R)
Just from looking at helms, it looks like putting a precision watch back together and I dont have a press to do the job
Old Jul 16, 2002 | 10:10 AM
BlueR's Avatar
press not necessary, do wetodd style, use your car and some pieces of wood
Old Jul 16, 2002 | 10:13 AM
Dave-ROR's Avatar
Press is not needed at all. You do need a 3 prong bearing puller and a few big fuggen hammerss, the right size sockey for the bearing is good too (to hammer it on, I think it's a 27mm). It's really really really simple on the inside, the diagrams look worse than it really is.
Old Jul 16, 2002 | 10:18 AM
Default Re: ATS Final Drive and Synchro install. Where to go? (Dave-ROR)
hmmmm....from the book, it looks like the ATS would go on the mainshaft, right?
And synchro's would be replaced on the countershaft, right?
Would it go to a point where the whole gear set would <U>all</U> be disassemble
Old Jul 16, 2002 | 10:22 AM
Dave-ROR's Avatar
You install the final drive on the diff. You have to disassemble the whole countershaft because you don't use the stock one with teh ATS or the stock first gear. So while you're reassembling the countershaft assembly, just replace the syncros.
Old Jul 16, 2002 | 10:28 AM
so only the mainshaft would be left alone?
Old Jul 16, 2002 | 10:29 AM
Dave-ROR's Avatar
yes. be careful with it though, nothing is pressed on it, everything will just fall of it if you flip it upside down.
Old Jul 16, 2002 | 10:35 AM
norice's Avatar
Having watched someone put an ATS in my transmission last weekend, I would not recommend it unless you are fairly mechanically inclined, or at least have watched someone else do it. It is not wildly complex, but getting everything aligned on the countershaft can be tricky.
Now I would be willing to try it, but I'm glad I didn't attempt it cold. The Helms can only explain so much.
Old Jul 16, 2002 | 10:39 AM
Default Re: ATS Final Drive and Synchro install. Where to go? (norice)
how long did it take for that person to finish your transmission?
Old Jul 16, 2002 | 10:49 AM
chad's Avatar
Moderator
&lt;--- drop tranny, install ATS, install clutch and flywheel and put tranny back on....4 hours!
Old Jul 16, 2002 | 10:51 AM
norice's Avatar
&gt; how long did it take for that person to finish your transmission?
I also had my clutch disc, pressure plate and flywheel replaced at the same time. The entire job took about 6 hours of unhurried work. Pulling the transmission and putting it back in the car takes most of that time. The actual gear work was probably about 90 minutes.
I used Jeff at http://www.hybridautomotive.com in San Jose. I would highly recommend him if you need some work done in the Bay Area.
[Modified by norice, 11:53 AM 7/16/2002]
Old Jul 16, 2002 | 10:55 AM
norice's Avatar
Default Re: ATS Final Drive and Synchro install. Where to go? (Chad)
Possible, yes. However, if you are doing it for the first time, I would suggest saving a whole weekend for it.
Old Jul 16, 2002 | 10:58 AM
my tranny is already on the ground. just needed to know how long did it take for the ats final drive and synchro replacement
Old Jul 16, 2002 | 12:15 PM
yoshi234's Avatar
I shoot brides
Jeff aka Jeff652
Old Jul 16, 2002 | 02:46 PM
D's Avatar
D
4 hrs is seriously busting ***... you definatly weren't drinking enough beer.
Old Jul 16, 2002 | 03:20 PM
Back in Black's Avatar
Rather OG
Default Re: ATS Final Drive and Synchro install. Where to go? (D)
No, actually 4 hour completion time can be attributed to a lift and air tools.
Jason-
who hates doing car work with standard tools after being spoiled at Chad's shop
