98 turbo lude atts unit slipping under load
Old May 25, 2008 | 01:22 PM
maste4269lude's Avatar
Default 98 turbo lude atts unit slipping under load
anybody had a simular situation? Fully builf h22 make 356 bhp at 14 psi thought to be a clutch problem but happens to be the atts slipping . I have a m2j5 lsd trans and tring to get a hold of pirate to get a int. shaft adapter plate
Old May 25, 2008 | 01:53 PM
Hawkze_2.3's Avatar
Default Re: 98 turbo lude atts unit slipping under load (maste4269lude)
It's common knowledge that the clutches in the ATTS start to slip at 250hp.
Old May 25, 2008 | 04:10 PM
lude98SH's Avatar
Default Re: 98 turbo lude atts unit slipping under load (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">It's common knowledge that the clutches in the ATTS start to slip at 250hp. </TD></TR></TABLE>
werent we discussing the legitimacy of that number awhile ago. It seemed that the 250hp mark was really just something ppl said a few years back and nobody actually came up with solid proof that 250 is the number.
Atleast that is what I remember, either way i cant see it withstanding a whole hell of alot of power....it just wasnt designed to handle that.
When it slips, the clutches inside the atts unit themselves are slipping....correct ? I would imagine that it would work just as any automatic trans car where you can upgrade the clutches and such. However i doubt there is anyone out there that has done it. What would running a fluid with a higher coefficent of friction do in that unit ?
Old May 25, 2008 | 04:15 PM
Hawkze_2.3's Avatar
Default Re: 98 turbo lude atts unit slipping under load (lude98SH)
I agree lude98SH, that's why I was saying starts to slip...who knows when it totally slips and becomes useless. It's not friendly to lots of power, that's for sure
Old May 26, 2008 | 08:13 AM
perk85's Avatar
i have a 2001 turbo lude and i had to disconect my atts i have no idea how your atts is even working. with the amount of horse power you are talking about you cant expect it to work. it was only designed to work up to like about 250 horsepower.
Old May 26, 2008 | 08:15 AM
perk85's Avatar
Default Re: 98 turbo lude atts unit slipping under load (perk85)
but if you get a hold of that pirate guy let me know if you got an intermediate shaft bracket
Old May 26, 2008 | 02:32 PM
its not actually working cause i run aem whichs isnt compatible its just there acting as an intermidiate shaft and i still havent got a hold of pirate
Havoc85
May 10, 2007 06:05 PM
Nihilation
Oct 6, 2004 10:28 PM
nver2
Feb 9, 2004 11:58 AM
graphic
Sep 30, 2003 04:49 PM
95GLX
Sep 7, 2003 01:32 PM
