do i need this for my swap?
Old May 25, 2008 | 01:20 PM
801ef's Avatar
Default do i need this for my swap?
Si to DOHC ZC Distributor Adapter
This will convert a Non-OBD (OBD0) 88-91 7-pin MPFI distributor plug to the 5-pin distributor plug with 2-pin External CPS plug. This is found on the DOHC ZC.
found it on rywire, also is there anywhere that i can jus order a dpfi to mpfi instead of havin to send in my harness
Old May 25, 2008 | 02:30 PM
801ef's Avatar
Default Re: do i need this for my swap? (801ef)
anyone?? i searched but got nothin... [freak] it
Old May 25, 2008 | 04:04 PM
Zdyned's Avatar
no offense to rywire but that part is a joke... all you need to do is depin the DX dizzy harness and pin it into an SI plug, it can be done so much cleaner then that gay *** adapter
Old May 25, 2008 | 04:53 PM
zccr-xsi's Avatar
Default Re: do i need this for my swap? (Zdyned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zdyned &raquo;</TD></TR><TR><TD CLASS="quote">no offense to rywire but that part is a joke... all you need to do is depin the DX dizzy harness and pin it into an SI plug, it can be done so much cleaner then that gay *** adapter </TD></TR></TABLE>
dude your a dumb *** STFU rywire makes a very good product.and even better custmer support.
if your not good at wiring thats what u need its plug and play.
if u got a jdm dizzy u can use the dx or tegg plug.(im useing a dx plug with my dohc zc u need to take the blue wire with green strip out and green wire with blue strip out of the clip and run them over to the cam sensor.for any real zc info go here http://www.thezcr.com
Old May 29, 2008 | 04:17 PM
MugenFlaredCRX's Avatar
Default Re: do i need this for my swap? (zccr-xsi)
I have that exact connector for my dohc zc swap in my crx. i got mine on ebay for about 25 bucks. its a lot better than having soldered wires or whatever. looks cleaner too. i'd say get one
Old May 30, 2008 | 05:01 AM
racintweek2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">
if u got a jdm dizzy u can use the dx or tegg plug.(im useing a dx plug with my dohc zc u need to take the blue wire with green strip out and green wire with blue strip out of the clip and run them over to the cam sensor.for any real zc info go here http://www.thezcr.com</TD></TR></TABLE>
you are a [freak]ing dick. that product however well made and supported is nothing more than a way to rip people off.
b-series cam seal and a MPFI dizzy
/ thread
Old May 30, 2008 | 09:03 AM
toolbox21's Avatar
You Can But Why Waste The Money All You Need To Do Is DepinThe DX Dizzy Plug And Re Pin The Si One On And Your Good
KevinEF7
Dec 24, 2012 12:34 PM
thedudefromjerz
Feb 20, 2008 08:53 AM
89cmutr
Jul 13, 2005 07:41 AM
juanb
Oct 27, 2004 07:47 PM
