Can't brake loose crankshaft nut
Old May 25, 2008 | 11:56 AM
fcarruth's Avatar
Default Can't brake loose crankshaft nut
Hey folks, I'm trying to replace my timing belt and a few other things on my 96 2.2L and can not get the crankshaft nut to break loose. Any help would be greatly appreciated since I would like to try to get this done over the Holiday weekend. I am at the point of getting it to TDC and then can not keep the pully from spinning once at TDC. I jam a large screwdriver in the flywheel area as you're suppposed to do but can not keep the pully from spinning.
Thanks in advance for any help you can pass my way.
Frank
Old May 25, 2008 | 05:48 PM
ControlledVortex's Avatar
Default Re: Can't brake loose crankshaft nut (fcarruth)
Here's what I know from my experience with the same issue. First of all, don't worry about TDC just yet, you can reset it after you loosen the crankshaft bolt. Just need to retighten it temporarily, then set it. You need to buy the special tool for holding the crank pulley while you loosen the nut. Do some searching on here, you will find the info you need. I followed all the recommendations, but still had to take it to a shop to have it loosened... $20 well spent. You will still need the crankshaft tool when re-tightening the crank bolt when you're done. Good luck!
Oh yea, check the FAQ section, good tutorial there
Old May 25, 2008 | 08:46 PM
jravensc's Avatar
Default Re: Can't brake loose crankshaft nut (ControlledVortex)
The crank pulley nut on my car was crazy hard to break loose. We used the honda crank pulley holder and jacked the car up about as far as we could. The point of jacking it up was that it gave us an angle to put the socket on the nut without using any extensions on the breaker bar. That decreased flex and allowed more direct torque on the nut. We also put a pipe on the end of the breaker, and just for kicks hit it with some PB blaster.
Good luck
Old May 26, 2008 | 12:51 AM
91h22cb7lx's Avatar
Default Re: Can't brake loose crankshaft nut (jravensc)
here is one version of the tool
http://cgi.ebay.com/ebaymotors...sting
there are a few differant versions around
shop around
Old May 26, 2008 | 05:57 AM
fcarruth's Avatar
Default Re: Can't brake loose crankshaft nut (91h22cb7lx)
Thanks for the input. I'll see what I can come up with but since I need this done today, I'll try a few more things and then put it all back together if I can't get it and then, try, try again.
Frank
z crx z vtec z
Northern California (Sales)
Oct 19, 2007 02:46 PM
dyslogical
35
Nov 20, 2006 11:30 AM
douglaslovin
Sep 15, 2005 06:42 AM
tuan...
Jan 15, 2004 06:48 AM
