rpms drop??? WTF is going on???
Old May 25, 2008 | 11:55 AM
skUnK2jdm's Avatar
Default rpms drop??? WTF is going on???
Hey guys I have 2000 honda civic hatch! I just recently installed a act lightweight flywheel and a exedy clutch, now 1000 miles later every time I push in the clutch the rpms drop almost turning it off! What is going on here??
any suggestions will help!!!
Old May 25, 2008 | 12:07 PM
imnotted's Avatar
Default Re: rpms drop??? WTF is going on??? (skUnK2jdm)
Umm...how much is engine speed dropping off? That's what is supposed to happen when you depress your clutch, you know. Engine speed is probably dropping more than with your stock flywheel because your old one weighed more and had more inertia to keep your engine turning between gears, but it should at least be above idle regardless of flywheel.
Old May 25, 2008 | 12:13 PM
skUnK2jdm's Avatar
Default Re: rpms drop??? WTF is going on??? (imnotted)
oh i should of been more clear, at idle if you push the clutch in the rpms drop to around 100-300 rpm.
and if you hold the gas at 2k rpm and push in the clutch the still drop down
BlueIntegraBoy's Avatar
Push the clutch in while shifting or while at a stop? While shifting, the RPMs will drop more than stock.
EDIT: Just read your post above. Not too sure why.
Old May 25, 2008 | 12:28 PM
skUnK2jdm's Avatar
Default Re: rpms drop??? WTF is going on??? (BlueIntegraBoy)
any1 else?
Old May 25, 2008 | 01:12 PM
skUnK2jdm's Avatar
Old May 25, 2008 | 05:18 PM
skUnK2jdm's Avatar
Lauj87
Sep 17, 2005 06:32 PM
dohcguy
Jun 29, 2005 04:18 PM
punkkazzjoe
Sep 25, 2004 09:49 AM
BlueTeg
Aug 4, 2004 09:31 AM
JdmAcclude
May 6, 2004 12:03 PM
