Car turned off on highway and wont start.
Old May 25, 2008 | 01:56 AM
IIXtremeHansen's Avatar
Default Car turned off on highway and wont start.
A buddy of mine drove his car on the highway at high speeds 90-110 and all of a sudden it blew black cloud, speed decreased and turned off. Tried to start and will not start. We saw oil but not alot around the back of the block to the bottum of the oil pan.
Starter works, fuel pumping, got spark.
We took the timing belt off and tried to turn the crank pulley but would not rotate for some reason. Can a cracked or broken flywheel keep it from starting?
Old May 25, 2008 | 02:56 AM
2004es2's Avatar
Default Re: Car turned off on highway and wont start. (Dickies_n_FlipFlops)
Whatever it is its not a cracked flywheel. It sounds like a problem with either the crank or really f'd up bearings.
Old May 25, 2008 | 02:57 AM
2004es2's Avatar
Default Re: Car turned off on highway and wont start. (2004es2)
Or their could be so much oil and junk in the cylinders that it cant compress at all.
Old May 25, 2008 | 08:39 AM
93b20z's Avatar
u c oil??... u sure a piston didn't pop out any coolant?... ans 90-110??... wat the heck?? racing??..
krypto2006
Aug 8, 2006 11:05 AM
TecHMec
Jan 31, 2006 06:00 PM
Simple
11
Jun 6, 2004 09:12 PM
Simple
Jun 6, 2004 03:21 PM
Malice
Jun 18, 2003 07:32 PM
