huge oil leak, gasket question...
Old May 24, 2008 | 10:29 PM
gotrice16's Avatar
Default huge oil leak, gasket question...
Hey, I bought an EG hatch with a JDM B16A from an SIR2...anyway, i noticed that if I drive hard and hit lift, I smelled more oil burning than usual. I drove it home and popped the hood to find that the trans is oily...I think my head gasket is going out...Is it okay if i used a head and oil pan gasket from a del Sol vtec? Are they compatible like most vtec b-series? I know not to use a GSR or any 1.8 or 1.7 liter gasket, but I'm not sure about the gasket...
also, I pulled off the transmission sticker and the car has the y21 trans from japan...how can i tell if it has LSD or not without pulling the diff. out?
Old May 25, 2008 | 11:07 AM
integ401's Avatar
Take a picture.You can use the gsr. Look up the part numbers for the b16 and the gsr. It's the same part number. To check if your tranny has lsd. Just jack the front end of the car up and put it in neutral and spin the wheel by hand . If one wheel spins one way and the other spins the other way. You don't have lsd.
Old May 25, 2008 | 09:50 PM
vtecb18c's Avatar
Default Re: huge oil leak, gasket question... (gotrice16)
yes their compatable..im using a whole b16a2 gasket kit on my 94 gsr
93sivtec
May 10, 2009 05:00 AM
Fezzie
Sep 27, 2006 01:33 PM
brnzbuddha
Jan 29, 2005 08:48 AM
thegreydog
Jun 3, 2004 04:23 AM
James
May 11, 2004 01:38 PM
