Any Suggestions?
I am currently building a D15B. So far I have everything but the ECU I have been looking at the Hondata S100 and S300, these chips are great but they have a lot of capabilities that i do not need. Also I am looking for a new intake manifold. Suggestions would be greatly appreciated.........
I can only make 5 post within a 24 hour period this is my 2nd so I am providing links and some info on my setup I am intending. It is a D15B it will be boosted 12PSI consistantly walbro 255lph fp 450RC injectors OBX fuel rail and FPR. Fidanza flywheel Gripforce clutch. Planning for the new intake maifold and ECU.
Here are the links. http://hondata.com/s100.html
http://hondata.com/s300.html
Also My email incase I am not able to post again today....
devin.fields@aa.mnf-wiraq.usmc.mil
P.S. Block is already complete as well as head work.
s100 would probally be more than suffcient for your setup. you have to think as s300 as the step right below standalone managment. it offers things like boost protection, diffrent boost rates for each gear, and can reconize things like 4 and 5 bar map sensors for a sh!# load of boost. The only thing is a stock map sensor can only read 11psi of boost so if you were that worried about 1psi then you would have to go with s300 and also a 3,4,or 5 bar map.
