complete harness swap? from ecu to engine...from a 92 si into 91 dx
can i swap a whole harness from the ecu to the engine .. i have everything from the 92 si... btw i will be running a d16z6 motor... the only thing i am worried about is where it connects to the fuse box.. or would i have to swap that too... has anyone done this ? any help is appreiated.. thx...
I have a 89 si sitting in my garage right now with a 90-91 dx motor, harness and dash.
The last owner had to swap out the entire dash harness to to the dx to make it work. I'm talking the entire harness. The ecu plugs are part of the dash harness witch is separate from the engine harness.
Were converting it back to MPFI.
Your best bet would be to do a MPFI rewire and then a OBD1 conversion.
the MPFI rewire I'm using.
http://www.angelfire.com/d20/h....html
Then buy a OBD0 to OBD1 conversion harness.
Good luck
Good luck
Tescrash
Feb 17, 2017 05:24 AM
crx-si
Sep 1, 2008 05:54 PM
Red_ED8
Jun 19, 2007 01:42 AM
