89 civic si ecu fuse keeps popping
Old May 24, 2008 | 05:54 PM
91siguy's Avatar
Default 89 civic si ecu fuse keeps popping
i have and 89 si hatch with single cam zc with obd 1 intake and dizzy ef si wire harness jumped to obd1 with po8. the ecu fuse keeps popping everytime i let off the clutch and put a load on the engine. engine idles fine and revs all day when is not in gear i need help
Old May 24, 2008 | 06:03 PM
Allday07's Avatar
Default Re: 89 civic si ecu fuse keeps popping (91siguy)
same here, cars fine all day and all, but last night it popped for some reason
Old May 24, 2008 | 06:06 PM
91siguy's Avatar
Default Re: 89 civic si ecu fuse keeps popping (Allday07)
any idea i let the **** idle for a good minute and jerked on all the engine harness and the under dash harness to check for and sorts to see if it would kill it but nothing...
Old May 26, 2008 | 07:14 AM
coupej1's Avatar
maybe loose engine ground?
Old May 26, 2008 | 07:43 AM
Allday07's Avatar
for my problem, i had my reverse lights unplugged because they werent working, and they hit the tranny casing..making them blow a fuse..i dunno keep looking around for frayed wires
Old May 26, 2008 | 07:56 AM
Ahknodd's Avatar
A loose ground won't cause a short and won't blow a fuse.
A frayed wire or a shorted component will definately blow a fuse though. You'll have too look for a power wire from the ecu that is shorted to a ground source, or a component the ECU drives that is shorted causing the ecu fuse to blow. Don't worry about ground wires or even sensor wires, those don't carry any amperage and that's what blows fuses. It'll be a power wire to something or a component for sure.
These are hard problems to diagnose, so dig in man, good luck!
Old May 27, 2008 | 11:12 AM
91siguy's Avatar
thanks for the help but everyone is just telling me stuff i already know im an ex nissan tech and ive asked a friend that works from honda and no one can figure it out i took out the engine harness un rapped it to look for any bad wires harness is fine
Old May 27, 2008 | 06:07 PM
Ahknodd's Avatar
Default Re: (91siguy)
Okay, then the harness is good. But did you check maybe an out put that may be shorted and causing the fuse to pop. something that the ECU grounds. I haven't had this happen, but maybe an injector or a solenoid, or something of that nature. I may possibly be the computer itself. I would try to borrow a computer and see it that solves your problem, if not then I would go to town checking everything that the ECU handles.
Electrical problems suck man. Sorry, but good luck!
Old May 28, 2008 | 01:50 PM
91siguy's Avatar
yea cause po8s grow on trees.. naw just kidding we're waiting to rull out the ecu last because it has to be something else i think the dizzy might be bad cause whatever it is its jumping up the amparge alot atleast 50 amps being pump through that 15 amp fuse
Old Jun 10, 2008 | 09:56 AM
Si-Samuri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91siguy &raquo;</TD></TR><TR><TD CLASS="quote">yea cause po8s grow on trees.. naw just kidding we're waiting to rull out the ecu last because it has to be something else i think the dizzy might be bad cause whatever it is its jumping up the amparge alot atleast 50 amps being pump through that 15 amp fuse</TD></TR></TABLE>
Where is this ECU fuse located??
EGKREW
Dec 20, 2008 08:33 AM
b18BoostedDC2
Jan 21, 2007 11:13 PM
Quick.Silver
May 24, 2006 11:56 AM
Civicracer193
Jun 1, 2005 02:01 PM
Muckman
Sep 2, 2004 11:37 AM
