difference between misfiring and/ rich or lean?
how can you tell if your car has a misfire at certain rpms, or if its hitting a rich or lean spot? i dont have a wideband.
rich or lean will produce the same misfire. There are differences between the two misfire are quite substantial .
What are you trying to trouble shoot?
Id get a wideband your almost playing in the dark there or you could check the plugs for lean or rich indications, or it could be ignition issues who knows.
